Old 04-03-2020, 12:58 PM
Terry M. Hunt Terry M. Hunt is offline
Default Gloss black?
Refinishing the plenum blower case on my ‘66 GTO. This is the part mounted on the firewall that blower motor mounts to on cars with a/c. Seems like most of these I’ve seen on restored cars were painted gloss black, but is that correct?
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 04-03-2020, 01:07 PM
ZeGermanHam's Avatar
The unrestored A/C box on my '66 is more of a satin like the other factory black finishes under the hood. I don't think gloss was used anywhere underhood, but I'll defer to the other experts here.
1998 BMW 328is (track rat)
Old 04-03-2020, 02:16 PM
RedDirtRoad RedDirtRoad is offline
Satin black on factory AC cars
Gloss black on standard without AC
Old 04-03-2020, 07:29 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Some misinformation in this thread.
There is Gloss Black used under the hood.
A couple examples are shown below.
Quoting the “Restoration Guide” which says the plenum blower case assembly was painted Gloss Black. I agree with this.
The standard Delco Voltage Regulator cover was painted Gloss Black also.
After 50+ years of dust and extreme heat under the hood the Gloss has dulled.
On a low mileage garage kept 1965 with 26,000 miles the blower case is gloss and firewall is a satin black.
The outside of the voltage regulator cover after rubbing with a dry cloth, Gloss Black.
The protected inside of cover, Gloss Black.
Chris.
ID:	536299   Click image for larger version
ID:	536300   Click image for larger version
ID:	536301   Click image for larger version
ID:	536302   Click image for larger version
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 04-03-2020, 11:40 PM
Default Gloss black
Chris, thanks for the definitive answer on this. The photos are most helpful. I got lazy and didn’t check my Restoration Guide like I should have. I’ve learned over many years that it is not 100% accurate, but a great source of detailed info. By the way, did you own a Reef Turquoise ‘66 with Parchment interior many years ago? Sorry if I’ve asked you this before.
Terry Hunt
Old 04-04-2020, 11:37 AM
60sstuff's Avatar
Hi Terry,
True, the “Resto Guide” is not 100% correct, but what is.
I still think it’s one of the Best resources for the GTO that’s ever been published.
The authors did a fantastic job putting that book together.
I did own a 66 Reef Turquoise with Black interior from about 1977-1984.
It was used by Revell for their cover art on this 1/25 scale model.
Chris.
