Old 03-30-2020, 06:49 AM
421/376 421/376 is offline
Default 66-67 Radiator support advise needed
::Hi , I could use some advice . I need to replace the radiator support on my 66 Tempest . It is non A/C, non ram air . There are a few repops available . I'd like to get the best quality one that I can get . The brands that I have located so far are:
Dynacorn
Goodmark
Golden Star
Any advise would be greatly appeciated . Thanks . Don
Old 03-30-2020, 09:15 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
I'll bet they are all the same, made by the same company in Taiwan. Just marketed by different companies in different boxes.
Old 03-30-2020, 11:27 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
What is wrong with yours? I would rather rebuild an original one or look for an original one. I have seen them on different sites.
Old 03-31-2020, 06:56 AM
Thanks for the replies . My support is bent in 1/2" near the top of the LH fender . It appears that the LH fender was replaced at some point . I noticed the problem when I saw a gap where the top of the grille meets the headlight bezel . So I'm trying to decide if it would be better to try to straighten the bent one or replace it . Thanks Don
Old 03-31-2020, 09:05 AM
MUSLCAH MUSLCAH is offline
If it’s rust free.....I’d bang on that Suckah !
Old 03-31-2020, 09:45 AM
That is a definite possibility . I guess I could drop the bumper , header panel and grilles and go at it . Worse comes to worse I could still get a repop . Thanks Don
Old 03-31-2020, 04:17 PM
Jonsie Jonsie is offline
Gotta do all that to replace it anyway, give it a shot!
Old 03-31-2020, 08:28 PM
Got any body with a frame machine....they could make quick work of that.
Old 04-01-2020, 05:56 AM
I believe I'm going to do the straightening method first. If it works it will save me some money . I'll try to play with it some time this weekend .I'll let you know how it turns out ' Thanks again for all the help . Don
Old 04-05-2020, 07:32 AM
Update, I am taking the car to the body shop tomorrow . I'll have them straighten it . Thanks for all your suggestions . Don
Old 04-05-2020, 09:43 AM
Good move.........a repaired rust free OEM support ...is way better than an aftermarket POS.
