Old 03-02-2020, 11:08 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Default Carburetor for slalom/time attack racing?
So I took my 81 T/A out racing yesterday to do time attack (slalom racing) through a cone obstacle course with high speed and very sharp/hard corners. My Holley 770 Street Avenger, which works well for straight acceleration driving and normal driving certainly struggled yesterday. With that said, would I be better off going with a Holley 500 or 650 2bbl carb for such adventures?
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 03-03-2020, 07:21 AM
steve25 steve25 is online now
You would be far better off with a Q-jet and it's one centralized fuel bowl and its plastic sloush cover.
Old 03-03-2020, 08:50 AM
PAUL K's Avatar
PAUL K PAUL K is online now
Installing floats with a wedge on each side will help. Quick Fuel pn16-55 or something like that. The floats will help with the right and left turns.
Quick Fuel 59-10 vent baffles will help with hard braking and acceleration.
Mechanical secondary carbs usually work better for that style of racing. If you have a vacuum operated secondary carb a lighter spring will should help.
Go fast, see Elvis!
Old 03-03-2020, 10:40 AM
shaker455's Avatar
shaker455 shaker455 is offline
Qjet will not work with his current intake T-2
Carburetor building & modification services
Servicing the Pontiac community over 20 years
Old 03-03-2020, 11:01 AM
Johnny406's Avatar
Thank you Gentlemen,
I was also thinking and perhaps overthinking but would a Holley 6425 650 2bbl carb be a good/better choice or perhaps a off-road carb like a Holley 770 Truck Avenger?
Old 03-03-2020, 01:39 PM
ta man ta man is offline
I would keep it simple and try a Holley 650 4777.
Old 03-03-2020, 02:15 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
That is what I autocrossed with on the 383 SBC 4 speed in the Camaro before the IA project with it.
Skip Fix
Old 03-04-2020, 01:31 AM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Give me the full specs on your current setup if you don't mind.
I have successfully built, tuned and campaigned carbs from Holley, Braswell and Bolaws in situations with over 3 sustained lateral G's and changes in direction of over 6.
It can be done with what you have ��
Working on going faster (and now staying dry at the same time !!)
The Following User Says Thank You to 455-4+1 For This Useful Post:
Old 03-14-2020, 09:40 PM
Johnny406's Avatar
I'm so sorry, I just saw this
Thank you for asking, I just finished rebuilding my Holley 770 Ultra Street Avenger carb and while at it, I installed trapezoid road race floats, spring loaded (off road) needle and seats as well as the off road vent tube. While waiting for those parts to come from Allstate Carburetor, I went ahead and dropped the tank and flushed it (cleaner than expected) and replaced the pick-up/sending unit.
At them moment I have a 625 Street Demon carb on it but I will be taking the 770 with me tomorrow as well to see how it does. I think the 625 is going to be a little small but I had a pair of them for 2x4 on the 78 T/A before I went to nitrous for the Street Outlaws heads up series here. If neither of these work, I'll order more parts and rebuild the 4777 650 DP I have.
Old 03-14-2020, 10:21 PM
tom s tom s is online now
I have a nice Holley Hemi carb with Lemans bowls that would work great for you!Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 03-14-2020, 10:38 PM
Johnny406's Avatar
Intrigued, I'll shoot you a pm.
Old 03-17-2020, 07:26 PM
455-4+1's Avatar
No worries, can you provide me with an email address, I can then send some info. Cheers
Old 03-17-2020, 08:23 PM
Johnny406's Avatar
I'll send you a pm, thank you for your time. I'm hoping life your way is less chaotic than here!!
Old 03-23-2020, 12:06 AM
455-4+1's Avatar
Reply sent, our country has now been placed at 100% lock down, oy essential /emergency services may work, everyone else is on home lock down and all domestic travel suspended....
I may have a bit of time on my hands in the next 4 weeks min lock down period
Old 04-09-2020, 02:27 PM
cgeise's Avatar
cgeise cgeise is offline
use a Holley sniper efi -- prob solved
Thread Tools
Display Modes
