'64 Convert, rear tack strip bolts.
Can someone tell me how many bolts hold in the rear convertible tack strips? Lag type screw going into sheet metal. My set up was a mishmash of different non-original bolts. Is it 3 or 4 on each side and 7 across the back? Also are they all the same size? I believe that several of mine were striped out and they just went to the next size up bolt. Thanks in advance for any assistance.
I see 9 across the back and 4 on each side. This is the strip from our host. Lag bolts should be the same length. DON'T use bolts to long on the sides!!!!
"Bill"! |
Thanks. It is pretty clear that someone has stripped out some of the holes in the body. I also did not have any of the rubber spacers in place. I am thinking about tacking grade 8 washers over the holes to get them back to correct size and act as spacer. Not sure what the outcome of going from rubber to steel would be.
