ARP2000 Head Studs
Any one looking an upgrade from the 8740 ARP stud, its possible to get a set that will work for a KRE HP head. There are 2 lengths 6 5/8" & 5 1/8" both can be cut at the block side of the threads up to 1 1/2". Just to throw it out there.
GTO George |
I’m kinda surprised the PA racers ain’t jumping all over this!
GTO George |
If you want the upgrade, but ARP doesn't already make a specific "package set" for your application, you can call them and have them piece together a "package set" from individual studs they have on hand for other applications. All you need to know is the length of each stud required and they can do the rest. It's cheaper than having them custom build you a "package set" from scratch. This is what I did for the funny car engine when I decided to keep it at 4 fasteners per cylinder with a dry deck and go with an upgrade to 1/2" studs.
So a question for you metallurgists-does the heat of cutting studs/bolt reduce the heat treating of them?
GTO George |
GTO George |
Old stud, new stud cut down and new stud.
GTO George |
GTO George,
Maybe it is just the picture. But can you mic the shaft (where there are no threads) of both old and new studs and tell use what the diameters are? Stan
It thicker then the thin part of the threads. GTO George |
Yes I could, be just wanted to double check that it was not the picture. The new studs are not for me. Glad you are happy with them. Stan
GTO George |
Anyhow, this is about what I paid ARP for my custom set for the funny car engine. It was about double what a standard set would run, but less than half for a "package set" had I got them to make it from scratch. They wanted more than $1100 for a set of studs if I had gone that route, so we pieced together a set from off the shelf studs intended for other applications.
GTO George |
GTO George |
Eric
Im positive it won't get close to 450 degrees. GTO George |
GTO George,
Are you cutting they dry or using a lubricant / coolant? Stan
GTO George |
Eric
