Old 03-27-2020, 09:15 PM
72pontiac's Avatar
72pontiac 72pontiac is offline
Default roof cross brace
does this look right kinda flat or is it bent down and should be curved up tight to
roof
Old 03-28-2020, 10:47 PM
72pontiac's Avatar
so I decided it is bent. I will either cut it at 4 points and straighten then reinstall or remove spot welds at 4 points straighten and reinstall or cut where I found the bend to be the worse then raise it and reweld. thoughts? roof seems to be fine. some bozo must got on there to watch the stars or something and pushed it down the roof went back up the brace stayed down
Old 03-29-2020, 12:47 AM
bdk1976 bdk1976 is offline
My '65 was worse than that - one of the previous owners must have shagged a beluga whale up there. I did what you are proposing and it worked well.
Old 03-29-2020, 07:22 AM
72pontiac's Avatar
Thanks for the reply
Did you take the whole thing out ? By spot welds or cut it out. Or were you able to make 1 cut and raise it
Old 03-29-2020, 09:56 AM
LATECH's Avatar
LATECH LATECH is offline
Try a bottle jack put an extension on it. Block it up squarely from the floor.Jack it back into place. You may need to put bracing under the floor to the ground so as not to bend the floor , but give it a gentle try first
You can lift a beluga whale with one.LOL
Old 03-29-2020, 03:09 PM
aceaceca's Avatar
aceaceca aceaceca is offline
Mine is similar. I was wondering does the brace go metal to metal with the roof or was there a deadening
material that went in there.
Old 03-29-2020, 04:20 PM
Cardo's Avatar
Cardo Cardo is offline
Deadening material goes in there.... expanding body foam or something like that.
"I know just enough to keep me here, but not enough to get me out"
Old 03-29-2020, 04:22 PM
LATECH's Avatar
Yes. Does NOT GO FLUSH to the roof .
Leave about 1/4 inch.
My 64 was in that area.Ijust recently finished a headliner, so I got to stare at the crossbrace for a little while.
I also put sound deadening material on the inner skin of the roof.Its OK to stuff the edge under the brace as it will keep it from rattling.
Old 03-29-2020, 04:41 PM
It’s been a while so I can’t remember, but I think I cut the entire cross brace out and carefully bent it back as close as I could to the original/roof contour, then welded back in. I also POR-15’d the underside of the roof and replaced the thin crumbly paper/fiber stuff that was underneath the braces/headliner with dynamat while things were accessible. Unfortunately it’s all buried under the headliner now and I don’t think I took any pics.
Old 03-31-2020, 08:30 AM
72pontiac's Avatar
I found a slight kink and cut just the ribbed part at that point which allowed it to bend up but still needs more help. I could use a picture as I don't know what its supposed to look like. is there a slight flat in the center or continuous curve about 1\8 inch down form roof
Old 03-31-2020, 09:18 AM
Cardo's Avatar
I think this is the only one I took. Hope it helps.
Old 03-31-2020, 09:26 AM
72pontiac's Avatar
Thats a pretty darn good pic thanks.
Old 03-31-2020, 06:35 PM
72pontiac's Avatar
Fixed it today by slicing it 7 times theough the ribs only. Then bracing it up to roof, welding cuts back together. it worked real well. With its arch back its stong again.
ID:	535909   Click image for larger version
ID:	535910   Click image for larger version
Old 03-31-2020, 08:33 PM
Cardo's Avatar
Looks good. Crazy how much work something like that can turn into.
