66-67 Radiator support advise needed
::Hi , I could use some advice . I need to replace the radiator support on my 66 Tempest . It is non A/C, non ram air . There are a few repops available . I'd like to get the best quality one that I can get . The brands that I have located so far are:
Dynacorn Goodmark Golden Star Any advise would be greatly appeciated . Thanks . Don |
I'll bet they are all the same, made by the same company in Taiwan. Just marketed by different companies in different boxes.
LEAD, FOLLOW, OR GET THE HE!! OUT OF THE WAY!!! HONEST JERRY'S SPEED AND EQUIPMENT
What is wrong with yours? I would rather rebuild an original one or look for an original one. I have seen them on different sites.
Remember no one is perfect. Everyone's butt has a crack in it! |
Thanks for the replies . My support is bent in 1/2" near the top of the LH fender . It appears that the LH fender was replaced at some point . I noticed the problem when I saw a gap where the top of the grille meets the headlight bezel . So I'm trying to decide if it would be better to try to straighten the bent one or replace it . Thanks Don
That is a definite possibility . I guess I could drop the bumper , header panel and grilles and go at it . Worse comes to worse I could still get a repop . Thanks Don
Gotta do all that to replace it anyway, give it a shot!
Got any body with a frame machine....they could make quick work of that.
I believe I'm going to do the straightening method first. If it works it will save me some money . I'll try to play with it some time this weekend .I'll let you know how it turns out ' Thanks again for all the help . Don
Update, I am taking the car to the body shop tomorrow . I'll have them straighten it . Thanks for all your suggestions . Don
Good move.........a repaired rust free OEM support ...is way better than an aftermarket POS.
