Old 04-05-2020, 12:07 PM
461-69bird's Avatar
461-69bird 461-69bird is offline
Question 68 firebird over axle exhaust
Anyone have pics of their 3" system that goes over the rear end?
Or
Would 2.5" from mufflers restrict a 600hp cae?
69 Firebird
472, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 10.90 @123
Old 04-05-2020, 01:00 PM
ta man ta man is offline
2.5 tailpipes will restrict, Mufflers ? depends if they are like an Ultraflow they may work..When I was running low 11's pulling the 2.5 inch tailpipes off a 3 inch front system and 2.5 Ultraflows I picked up a solid tenth and 1 mph..maybe a tad more
Old 04-05-2020, 01:19 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is online now
I will try to get some pictures tomorrow. I have 3" over the rear on my 67 Bird. I did move thebrear or the springs over 1-1/2" with some offset bushings. But i had 3" on it woth the springs in the stock location too. Moving the springs made it easier when I re-made the tail pipes and added tire clearance
Old 04-05-2020, 03:39 PM
mback12000 mback12000 is offline
System on my 68 Firebird from RARE. It uses 3" tailpipes with oval 2x4" head pipes and X-crossover. I ordered custom made Spintech mufflers with a 3" thick case because I am anal about a low handing exhaust and all the popular off the shelf mufflers are 4 3/4" thick. Mufflers were made with 2x4 oval in and 3" round out. According to Spintech these mufflers eat less than 10hp on 800+hp alcohol Outlaw motors, but they are pretty loud. I also cut the tailpipes to install V-band clamps for service but installed them on the kick up part of the tailpipe because the V-band OD is more than 3" and would be a catch point. Note the tailpipes did require a few cuts to fit the way I wanted them as well as a very small pinch in the vise to get another 1/8" fit between the quarter and leaf spring. I didn't use the RARE hangers, fabbed up something instead. Now I just have to raise the headers a bit to be happy. Note some of these pics are before final welding.
Name:	2019-08-10 17.05.26.jpg
ID:	536431   Click image for larger version
Name:	2019-08-10 17.05.12.jpg
ID:	536432   Click image for larger version
Name:	2019-08-10 13.49.42.jpg
ID:	536437   Click image for larger version
Name:	2019-08-10 16.17.55.jpg
ID:	536438   Click image for larger version
Name:	2019-08-10 17.05.02.jpg
Mike B
1968 Firebird
Old 04-05-2020, 05:42 PM
Nice work!!! Mine looks like a hack job compared to that.
Old 04-05-2020, 05:52 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Clean.
Old 04-05-2020, 08:57 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Some pics here of a 3" exhaust we put on my brothers a 67 bird.
http://forums.maxperformanceinc.com/...523734&page=14
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 04-06-2020, 03:34 AM
461-69bird's Avatar
Thanks guys. Typo meant 69.
Already have 3" system and Dynomax ST mufflers with turn downs before the axle. Always run at the track through the exhausts but I'm looking at using tail pipes to get the gases out the back rather than underneath.
69 Firebird
Old 04-06-2020, 07:47 AM
chuckies76ta's Avatar
Here's a couple of pics of the 3" tail pipes on our 68 Firebird. The tips are also 3". Pipe is all Mandrell.
ID:	536492   Click image for larger version
ID:	536493   Click image for larger version
ID:	536494   Click image for larger version
Old 04-06-2020, 09:30 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Who's 3" splitters?
Skip Fix
Old 04-06-2020, 12:49 PM
Pypes carries them EVT13.
https://www.lmperformance.com/859507...splitters.html
Old 04-06-2020, 02:05 PM
Skip Fix's Avatar
Cool I want to think their originals were 2.5 just bumped to 3 at the weld on spot.
Skip Fix
Old 04-06-2020, 03:17 PM
No the ones I have are 3” inlet with 2-3” outlets.
Old 04-15-2020, 12:39 PM
leeklm's Avatar
leeklm leeklm is offline
I used the 3" flowmaster pipes with H, running into 14" Ultraflows. Looks similar to pics below.
The one issue I had was a very tight clearance between the leaf spring and qtr panel, which would often times rub on one or the other.
I cut 8" or so off of the tail pipe and installed 2.25" chrome tips to provide better clearance. I initially did this using a clamp so I could do back to back testing at the track, which showed zero difference running the 3" or 2.25" tip. I since welded the tips on to clean it up and get rid of the cumbersome clamp.
Couple of pics
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
