#101
More pics of Passenger side 1/4 panel.
68 Firebird Coupe 350/Auto/Air 70 RA III Formula/Auto/Air 71 T/A 455HO/Standard/Air 73 T/A 455/Auto/Air |
#102
very few people or shops use lead. i use fiberglass reinforced filler (tiger or gorilla hair) for any type of seam that has depth to it like the quarter panel. did mine back in 98-99 and have put it through a lot of abuse, including running drag radials at the strip (12-0s) and no signs of cracking or shrinking. metal to metal or all metal would likely be ok, but i prefer something that has a more interconnected type of filler reinforcement of any area that's going to see a lot of stress.
#103
Worked on 73TA some more. Started working on passenger side quarter panel.
#104
As you can see my trunk drop off is shot, Here is one that I blasted, need to try to fill the holes, lots of welding......
#105
Nice weather + Layoff for week = Work on Car.
Well I got furl-lowed at work, basically lay ed off one week a month. Times are tough, Guess I will work on the car some more on my time off. I worked on the passenger 1/4 panel some more, Here are the pictures. Hope things get better so I can buy the rotisserie I wanted to buy, getting close to needing it.
#106
more 1/4 panel pics.
#107
More Progress
Finished trunk drop off, and welded it in.
#108
Clamped patch panel onto 1/4, And welded into place
#109
more welding.
#110
And after grinding.
#111
Nice job keep up the good work and pics ,,,were did u get those clamps look like a very useful tool there on the panels....Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
#112
Agreed the work is great and those clamps caught my eye as well?????
#113
I got the clamps at Harbor Freight Tools.
#114
What the heck do ya call them LOL
They look like a neat tool and hold the panel perfect it looks like..better than maganets I would think huh??
#115
Item # 44751 @ Harbor Freight tool. They are called butt welding Clamps and come in a set of eight.
#116
Heres the link to buy them at harbor freight tools. http://www.harborfreightusa.com/usa/...o?itemid=44751
#117
Great thanks wwilder9
#118
Bolted tailpan to car, test fitted lights, fiberglass filler panel, and rear spoiler.
#119
Then I started welding the tailpan onto the car.
#120
More progress
After getting tail pan welded into car had to weld on the trunk lock bracket and studs for the lock itself, also the bracket that goes inside the bumper in the center.
