Repop Dust Caps
Has anyone purchased the correct looking caps sold by cssbinc? I'm wondering if they fit our cars okay?
http://www.ebay.com/itm/1969-82-Corv...19.m1438.l2649 |
These are good for the rally wheel hub locks, I have tried them on cars I have done the center cap lock mods on. That said originals had a rounded top , not a flat spot.
I just did my front brakes recently. As I recall the original had a wavy front lip where it mates to the hub so you could stick a screwdriver under there to pry it up. And yes, as Bruce says ours should have a rounded top.
I have NOS 3984810 ones and they are same as my originals in shape - take a look.I can get more pictures of these and originals next to each other if it would help....
Chad .
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant http://www.ford-trucks.com/forums/12...al-ranger.html 1966 Ford F250 4x4 Red/White 4-speed - San Jose plant 1966 Ford F250 4x4 White 4-speed - San Jose plant http://www.ford-trucks.com/forums/11...-f250-4x4.html 1971 Trans Am White/Blue 4-speed limited options - Norwood plant http://forums.maxperformanceinc.com/...d.php?t=757496 |
http://www.ebay.com/itm/NOS-GM-OEM-7...FUhwkb&vxp=mtr The 1970-71 caps had a straight edge where they meet the rotor. Chad .
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant http://www.ford-trucks.com/forums/12...al-ranger.html 1966 Ford F250 4x4 Red/White 4-speed - San Jose plant 1966 Ford F250 4x4 White 4-speed - San Jose plant http://www.ford-trucks.com/forums/11...-f250-4x4.html 1971 Trans Am White/Blue 4-speed limited options - Norwood plant http://forums.maxperformanceinc.com/...d.php?t=757496 Last edited by TA455HO; 08-15-2017 at 10:58 AM. |
Here's a picture of two originals on the right, two NOS in the middle and two repros from Corvette Specialties on the left. I think the repros here compare very favorably to the others. The top of all of them is not perfectly rounded, but not flat, either. They sort of reach a first apex coming up the sides and then slightly less rounded from there to the peak.
Chad .
Chad, thanks for the pics.
Mine look like Chads
Mine used to -- they're all dented up.
I just picked up these nOS beauties for $16 shipped.
http://www.ebay.com/itm/1959-72-Corv...vip=true&rt=nc They will be cleaned, satin clear coated, and installed on my '77.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
I see these are different from the others pictured. 72 and later.
Not sure? But, my early 72 look like the TA455HO pix...
Mike/Illinois |
The 6274217 was definitely used from the factory on my '76 LeMans, as well as my '77 Trans Am and every Can Am I've owned. I will check my '73 Grand Am to see if it used that style.
The 217 superseded the 3984810. So the 217 while the correct replacement is different in design than the part it superseded
Some time in the 72 run must have been the switchover point.
I ordered a couple from CS. Last edited by FunctionalShaker; 08-23-2017 at 06:51 PM. |
OK, enough about dust caps. I want to hear some chatter about your valve stems and lug nuts.
The 217 caps were used in '73.
My source was an early seventies parts catalog.
I'm here to please. Broke out these NOS valve stem caps for the BIG show in Dayton this weekend, I think they will put my car over the top.
Man, those are nice. Will you take those off at night so nobody steals them?
