Old 12-03-2017, 03:05 PM
Kevspontiacs@aol.com's Avatar
Kevspontiacs@aol.com Kevspontiacs@aol.com is offline
Default Filters w/shaker
https://www.knfilters.com/mobile/mPr...px?prod=E-9233
I've been tinkering around with my 76 and finally put a block off plate in the air filter base where the snorkel used to sit. Then I got to looking inside the scoop and noticed that there wasn't a whole lot of room between the filter lid and scoop. So that got me to thinking and this is what Ive come up with. Was going to use it in place of my factory lid. I bought an $18 wix from O'Reillys. It will be here on Tuesday.
Anyone else do something similar??
Kevin
Old 12-03-2017, 03:22 PM
hal101's Avatar
hal101 hal101 is offline
how about this one you can buy the filter sep
https://butlerperformance.com/i-2718...tegory:1234827
Old 12-03-2017, 04:17 PM
I like the filter on that but mine is still factory intake with Quadra jet, no drop base needed.
If my double stack filter idea doesn't work I may call Dave at Pro Touring F-body, looks like he's the one that makes them, and see if i can just get the filter and top
Kevin
Old 12-03-2017, 06:29 PM
cnc's Avatar
cnc cnc is offline
I Run this setup, factory base and I modified the lid to fit the air cleaner....
I just push the filter slightly towards the firewall it's tight ...I also use them 70-72 wing nut shaker mounting not the big band clamp
I do have a very small gap at the frt of the assembly when it's together.....so would it work with a clamp MAYBE...???
ID:	469374   Click image for larger version
ID:	469375   Click image for larger version
ID:	469377   Click image for larger version
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 12-03-2017, 07:09 PM
hal101's Avatar
wow i like that one
Old 12-03-2017, 07:33 PM
77 TRASHCAN's Avatar
Chris,
Job well done! gap at front doesn't really matter...
You doing anything this winter to your car/engine?
Jeff
Shut it off
Shut it off
Old 12-03-2017, 09:13 PM
cnc's Avatar
cnc cnc is offline
Originally Posted by 77 TRASHCAN View Post
Chris,
Jeff
Thanks Jeff
I did that a little while back. I should have left the lid a little larger in diamater........can't remember when I made it....lol
Well........looking at converter change 10" 3200-3500
Torquewar is gonna be doin some engine stufff and converter change so might be able to run his 3200-10" Continental and see how it works with my combo....
Old 12-04-2017, 10:35 AM
Thanks Jeff
I wonder how the Old Faithful cam would do with your combo???
Shut it off
Shut it off
Old 12-04-2017, 09:46 PM
Torquewar's Avatar
Torquewar Torquewar is offline
The filter system i have is the same as CNC, we actually both played with this idea one afternoon. I have a older butler drop base but we both used a used a conical filter with a cut down TA lid.
The filter is a Air-Raid. Think its 14 dia on the bottom and 10 top. I have a 1/2 spacer under the filter to raise it up to its max . When in the shaker its really tight with about a 1/8 clearance. The goal at the time was to get a big amount of distance above the carb. I run this on 2 different set ups. A quad with RPM and a T-2 with a 4150.
With mine i have 3 1/2 to the top of the carb. I run this at the strip and there are not any issues. This topic has been covered before and there are couple variations of making it all work .
If i could figure out how to post a pic......
Old 12-04-2017, 10:00 PM
cnc's Avatar
cnc cnc is offline
Originally Posted by hal101 View Post
wow i like that one
Thanks ...
Old 12-04-2017, 10:03 PM
cnc's Avatar
cnc cnc is offline
If i could figure out how to post a pic......[/QUOTE].
Old 12-06-2017, 08:18 PM
I picked the filter up on Tuesday. Wix # 46027. It just took just a little bit of trimming on the paper element to clear the sides of the scoop. Since the top was plastic, and I didn't think it was strong enough to hold everything in place, I bought a stainless 6 inch cleanout cover from lowes that fit the top mint.
Granted now I have two air filters to replace but it has to breathe WAAAAY better
Kevin
Old 12-07-2017, 04:45 PM
Lee's Avatar
Lee Lee is offline
Kevin
My local Autozone had the Fram version of that filter in stock. I actually tried to fit it on my '73 last summer, but just didn't have room. If I had cut back the filter in a few places it may have, but I did not like that idea.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
Old 12-07-2017, 05:47 PM
SD73's Avatar
SD73 SD73 is offline
After seeing that part number I found the K&N equivalent (E-2933). They told me it would likely be too wide for my base K&N I am using which is E-1590. They did give me a part number that I need to check with some more and get some measurements. It's K&N 66-1202. It's sort of like the XTreme lid, but it has some height to it. The outer diameter is too large though. 15 inches if I recall. I've asked for the width of the inner lips just to see if it would have enough of a lip to set on the bottom filter. The air cleaner lid is 13 3/8 so it may be a long shot.
Old 12-07-2017, 07:32 PM
SD73's Avatar
Here's a pic of the K&N 66-1202
