E85 on a bracket car questions
For those of you running bracket drag cars that converted over to E-85, was it worth it? Was your car more consistent than with gas? Does it need more advance to light?
The car in question is my 78 T/A with the specs in my signature @ 11.25:1 compression. I've been flirting for years of going to E-85 and now that we have several local gas stations selling it, I'm more tempted than ever as I have to drive about 30-40 miles round trip to buy VP 110 race gas. The good news for me is that I'm running a E85 compatable Aeromotive fuel pump and 1/2" aluminum line which helps. I will have to check and see if my bypass regulator is E85 capable.
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac Last edited by Johnny406; 11-27-2020 at 02:14 AM. |
If you have it local I think its a no brainer. I travel up to 30 miles to get it, but to be honest when I went to Norwalk two summers ago I loaded up with about 100 gallons of the good stuff. this can be used to supplement the 'worse' local stuff. Ohio tested at 87% or so my local stuff ranges from 70-82% I haven't got out much last year obviously. but for a street car or dual purpose car I wouldn't hesitate. I do not think there is a huge performance advantage, in fact there may be a slight loss, however that could be due to carb not being optimized.
at your compression range, you likely wont see any benefit but cost per gallon. I haven't sprayed on it yet, but I will likely give that a 200 shot next year. Car is set up for it why not, lol now to be fair, my new bracket motor most likely will be running alcohol, only reasons are, I bought an APD billet carb for a reasonable cost, and I know I can get methanol at any track. I plan on chasing points in 2021 and the thought of having to switch fuels, or run to ohio for fuel, is troublesome. I also feel the methanol is superior in cooling for bracket racing. This is a dedicated race car, not a street strip car like the gto. That being said, it has been raced almost exclusively on e85 since I got it 4 years ago.
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
I tried e85 last year my car 10.6 -1 car was inconsistent with the pump stuff went back to pump gas my experience anyway
How much did you richen the jet in the carb when going E-85?
I had a 950 set up for my combo took off and put on the shelf
Any interest in selling that carb?
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
Yes I can text you information on it when I get home pm me your cell
I sure will, thank you
Hello, I switched over to E-85 about five years ago, it is the best fuel out there for the budget minded racer. my car has run 9.50 @ 140 on it.
