Old 06-19-2019, 03:12 PM
67TIGER's Avatar
67TIGER 67TIGER is offline
Question Fan Clutch Question
Looking at the attached pictures, does my fan/clutch unit look to be too far from the radiator? I'm measuring 3" from the face of the clutch to the radiator.
Engine is running a bit hotter than I like and I want to try and find out why one step at a time.
Could anyone with a 1967 GTO no air take a look at their fan clutches and see how far it is from the radiator.
Name:	Fan Clutch To Radiator Space 3 Inches - 01.jpg
ID:	514480   Click image for larger version
Name:	Fan Clutch To Radiator Space 3 Inches - 02.jpg
1967 Pontiac GTO
1965 Olds Cutlass
2014 Ford Mustang
GTO-The Great One for 1967
Old 06-19-2019, 03:24 PM
richardk's Avatar
richardk richardk is offline
Did you take off the fan shroud for clarity or are you running without one? If without then adding one will likely help a great deal. The fan blades should be approximately half in and half out of the shroud.
"I fishtail through the lanes, and I make my tires squeal.
Power at my feet, and glory at the wheel.
I wind the windows down, let the wind blow through my hair.
God knows where I'm goin' to, but me... I don't care."
Old 06-19-2019, 03:40 PM
gtobob67 gtobob67 is offline
Just a shade under 3" on mine. You're good there. I have a shroud also.
Old 06-19-2019, 04:00 PM
67TIGER's Avatar
Ok, it looks like it is farther back than what I thought it should be. I'm looking at replacing it with the 2747 Hayden HD Clutch, I looked at the measurements and it looks a bit taller (3.34" Total Height) than what mine is. Maybe it will move the fan a little closer to the radiator.
No my GTO did not come with a fan shroud, I would like to address each one of the cooling system problems (?) before going that route. If everything else fails, I guess I will have to install one.
This car has lived all of its life here in the heat and humidity of North Carolina. I don't think the 400 has been running hot all these years.
I'm sure that it's something I have missed or overlooked. I'm going to be looking at all the usual Pontiac problems and dealing with them one at a time.
Thanks, I appreciate all the feedback.
1967 Pontiac GTO
1965 Olds Cutlass
2014 Ford Mustang
Old 06-19-2019, 04:59 PM
george kujanski's Avatar
I'd say it looks too far from the radiator for me. I suggest adding a shroud......that way the fan will move more air thru the radiator instead of just moving air around the the underhood area. Biggest bang for the buck there.
George
67TIGER's Avatar
Here are a couple of pictures I saved that show the fans closer to the radiator than mine.
I don't know who these belong to, I'm just using them as a reference.
Name:	1967 GTO 400-Note Water Pump Pulley Finish - 01.jpg
ID:	514486   Click image for larger version
Name:	1967 GTO 400-Note Water Pump Pulley Finish - 02.jpg
1967 Pontiac GTO
1965 Olds Cutlass
2014 Ford Mustang
Old 06-19-2019, 05:05 PM
richardk's Avatar
I don't want to seem like I'm telling you what to do or to keep harping on the same subject but you should have a shroud. I've never seen a car with a clutch type fan that didn't have one. It will definitely make your fan much more efficient.
I've said my piece, good luck with whatever you decide to do.
Edit: When I get home tonight I'll measure mine and let you know the result.
Old 06-19-2019, 06:08 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
All 1967 GTOs left the factory with a “Fan Clutch” and most did not come with a shroud. This also holds true for 64-65-66.
All “Air Condition” cars automatically came with a shroud, but Non-Air cars did not.
There was a fiberglass Dealer shroud available which was recommended for trailer reasons.
I have this Dealer shroud #9774621 on my 66 GTO.
This is spelled out on page 366 of the Restoration Guide.
My two cars are Factory Original including the fan and OEM clutch and they both measure (4 inches) from radiator core to front of fan metal hub.
I agree that the shrouds help with cooling these cars down.
Chris.
ID:	514490   Click image for larger version
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 06-19-2019, 06:32 PM
Gator67's Avatar
Gator67 Gator67 is offline
The 462 in my '67 doesn't get much higher than 185 even sitting in traffic in the middle of the summer here in AZ. Other than the aluminum radiator, everything else in the cooling system is factory. The shroud came with the car, but I don't believe it's correct. It fits OK, but night tightly against the radiator. I have 3" from the radiator to the parting line of the clutch, so about 2.5" to the face.
Old 06-19-2019, 06:40 PM
richardk's Avatar
Chris.
Guess I should have waited til I got home and consulted the Restoration Guide before implying all cars had shrouds though it's true most I've seen had one.
Anyway, measurement from the face of my fan clutch to radiator is only 2 inches and 3 1/2 inches from fan hub to radiator.
Old 06-19-2019, 07:11 PM
67TIGER's Avatar
Thanks guys for taking the time to get the measurements, that really helps a whole lot!
First thing I'm going to do is install a small temperature gauge under the dash, I know I should have done this from the start. I want to see what this thing is running as a base line, may not be as bad as I think.
It just has a hard time when the outside temp is in the 90's & up, other than that doesn't seem too bad. Temp gauge should answer a lot of questions.
Thanks again!
1967 Pontiac GTO
1965 Olds Cutlass
2014 Ford Mustang
Old 06-20-2019, 06:59 AM
chrisp chrisp is offline
What brand radiator ?
Old 06-20-2019, 10:26 AM
Gator67's Avatar
Radiator was built by Mark 7 in Bay City Michigan. Not sure they're still around.
