Old 06-03-2007, 08:31 PM
cas cas is offline
Default th 400 fluid leak
I have a leak on my th 400 it seems to be coming from where the shift lever arm goes into the case. Is this a common leak point and what's the best fix?
I thought the leak was coming from the pan gasket or speedo hub, they were both replaced with new seals. now it seems to leak more than before. Any help would be great
68' Lemans conv.
69' GTO conv.
Old 06-03-2007, 11:53 PM
cuz68's Avatar
cuz68 cuz68 is offline
Wink
Bad O ring behind it.
Cuz68
Old 06-03-2007, 11:55 PM
cuz68's Avatar
Wink
Bad O ring behind it.or the O ring on the speed ometer.
Cuz68
Old 06-04-2007, 12:01 AM
GTO Noob's Avatar
GTO Noob GTO Noob is offline
Since you replaced the Speedo seal I would say that it's a bad oli lip seal on the shift lever
Old 06-05-2007, 05:20 PM
cas cas is offline
I guess I have to get inside the pan again to get the shaft out to replace the o-ring?
68' Lemans conv.
69' GTO conv.
Old 08-14-2007, 02:28 PM
Vol's Avatar
Vol Vol is offline
I am having the same issue. I have replaced the tranny pan gasket, the small speedometer gear O ring and speedometer cluster O ring, new speedometer cable too and it is still leaking. I did check for cracks in the aluminum speedometer cluster and found none.
My question is this. When pulling out the speedomenter cluster should fluid come out if the car is level? I remember trying to set the speedometer gearing right for car a long time ago and I was able to swap it out on the road with no fluid coming out. Does my tranny have to much fluid in it possibly? I drained it completely and added 4 quarts to it. I read some where that a drained 400 will take 3.75 quarts to fill up. The torque converter was not drained.
Old 08-14-2007, 04:59 PM
cas cas is offline
vol, a good source told me that you should be able to pull the speedo out with the fluid not drained. you might lose a little but nothing to make a big mess. By the way I think mine is leaking from the seal at the converter. Fluid runs down the converter and blows back onto the pan. With the flywheel cover on, it caught the fluid and left a six inch puddle when stopped after a ride. It doesn't leak at all when it is just sitting.
68' Lemans conv.
69' GTO conv.
Old 08-15-2007, 12:41 AM
Vol's Avatar
Vol Vol is offline
I plan to start the whole process over with a new kit. I know the front and rear seals are good. I will replace the shift lever seal, pan gasket and the two O rings in the speedometer, add in fluid and watch it for 4 hours to see if I get a drip. BETTER NOT this time around.
