Old 01-26-2003, 09:05 PM
Tom McQueen Tom McQueen is offline
I am getting to the wiring phase of this project. Am definitely going to use a remote solenoid, but which specific one? Or is it pretty much irrelevant.
Check out my 70 GTO build;
http://www.yellowbullet.com/forum/sh....php?t=1148602
Old 01-27-2003, 05:45 AM
chucks79ta chucks79ta is offline
I used the Summit brand set up it works great and was under $20 bucks. I also used a 4 gauge cable from the solenoid to the starter. No more hot start problems. Chuck
1979 Trans Am 1975 Formula
Old 01-27-2003, 09:34 AM
DAVE RIBEIRO DAVE RIBEIRO is offline
Ask for Scott E. @ Summit
Make sure you mount it in a easy to service location on the firewall,not where a wrench can
fall and short-out the system...also easy to replace ??? Run a heavy wire or clip across the
starter,with a #2/4 cable to the starter..You will
also enjoy the ease of tuning/valve setting/comp.
test etc..I really can't beleive that FORD came up
with the system (only-kidding) good-luck..Dave
Old 01-28-2003, 09:03 PM
I have placed several orders with Scott at Summit. I am going to order the Painless setup from him so I guess Ill just get the Summit Solenoid as well. Thanks for the input.
