Old 05-08-2021, 07:40 AM
firefour1 firefour1 is offline
Default 4 cylinder distributor
Originally Posted by katorocks View Post
I am looking for a 63 4bbl 4 cylinder air cleaner, front bumper, driver mirror, turn signal stalk, and distributor. Trying to revive this bronze beauty. Please help a lemans newbie out!
I have the 4 cylinder, let me know the city and zip where you live.
  #382
Old 05-12-2021, 03:37 AM
katorocks katorocks is offline
Message sent. I found all of the distributor internals just need the front bumper and air cleaner stuff as well as the headlight trim rings.
  #383
Old 05-25-2021, 01:34 AM
rod cole rod cole is offline
Default hood springs
Anyone have 61-62 hood springs or spring they will part with? Thanks Rod
  #384
Old 05-25-2021, 02:55 AM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
Have a set of 63 hood hinges with springs?
  #385
Old 05-25-2021, 10:51 AM
Mine are approx 7 inches long and 1 3/8 around. Are the 63 that size and how much. Thanks Rod
  #386
Old 06-03-2021, 05:33 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Default Parts for 63 Lemans sport coupe
Outside trim for a 63 Lemans sport coupe gasket style windshield
  #387
Old 06-18-2021, 03:57 PM
Greenway Greenway is offline
Default 62 transaxle parts
Hello. I'm looking for a pinion bearing retainer (part # 542406) and pinion bearing (part # 7450984) for a 62 with 3 speed manual. Thanks!
  #388
Old 09-06-2021, 01:18 PM
Sanduners's Avatar
Sanduners Sanduners is offline
Default Harrison Radiator
Looking for a stock 4 row Harrison radiator for my 63 Lemans. Part number is 3158857. Thanks!
  #389
Old 09-11-2021, 02:29 PM
mchlmacdonald mchlmacdonald is offline
Looking for a 2-barrel or 4-barrel intake for a 4-cylinder 1962 Pontiac tempest.
Also looking for a 4-speed transaxle, need everything from the bell-housing back.
Also need a front and rear suspension bushing kit. Are these available anywhere?
  #390
Old 09-11-2021, 02:41 PM
tom s tom s is offline
They did not make a 2bbl 4cyc intake.1bbl and 4 bbl.Tom
  #391
Old 09-12-2021, 07:20 PM
TransaxleTempest62 TransaxleTempest62 is offline
Kanter has the front, Ames has the rear
  #392
Old 10-06-2021, 01:21 PM
Big Squeeze Big Squeeze is offline
Looking for a new or like new pitman arm for a manual steering 62 Lemans
Wayne
918-697-6965
Pump gas and hydraulic cams are for minivans.....
www.smotherssupercars.com
Check out my Performance Engine Building and Carburetor Tuning DVD.........
  #393
Old 10-06-2021, 02:39 PM
These are sometimes on ebay but for the most part hard to come by.
Several good places, amesperf.com or rareparts.com
Note that rareparts.com will rebuild your existing one. You box it up and ship to them, they rebuild and send it back in about 10 days.
  #394
Old 10-13-2021, 05:40 PM
sberbs's Avatar
sberbs sberbs is offline
Looking for a V8 cross member
Sent from my SM-G998U using Tapatalk
  #395
Old 11-06-2021, 05:45 PM
Lwqualtieri Lwqualtieri is offline
Looking for a 4bbl intake manifold (4cyl)
Also
Looking for power brake booster and bracket
1963 tempest convertible
  #396
Old 01-30-2022, 03:31 PM
Halfthrottle Halfthrottle is offline
Default 63 Tempest Lemans Front Fascia
1963 Tempest or Lemans. I need both the upper and lower section of the front end. Also the pot metal outer trim pieces. Little rust or dents ok, but needs to be overall solid. Do not need the headlamp buckets, lights, emblem or grills. Need asap.
  #397
Old 01-30-2022, 05:02 PM
I have one side of the pot metal part that goes on outside of headlight (sometimes called eye brow). $35 + shipping
  #398
Old 01-31-2022, 01:30 PM
I found the front end thanks everyone.
  #399
Old 04-01-2022, 07:55 PM
hobbygto65's Avatar
WTB Stainless windshield trim for gasket style window. 63 sport coupe.
  #400
Old 04-05-2022, 01:47 PM
62tempestlemans 62tempestlemans is offline
Need a passenger side door window channel for a 62 Tempest lemans 2 door sport coupe. Mine is rusted out.
