#41
I ran a Cam Dynamic 228/228 @ 0.050 in my stock low compression original 78 180 HP motor. It was lumpy with th estock lean calibrated Q jet smoothed out great with a 73 SD Qjet that had better idle circuit.
#42
We finally got everything back from the machine shop, so we will get started putting this thing together before too long. A question about the installed position of the 2802 cam, Cam card says to install it at 109° Intake Centerline. Since we are installing it with everything brand new, including the billet Cloyes timing chain, should we put it in a little advanced, say 107°, to allow for a little chain stretch during break-in? Or just install it at 109° and let it end up wherever after a little chain stretch? Thanks!
1978 Trans Am Pump Gas 461 Stroker |
#43
"No replacement for displacement!" GTOAA--https://www.gtoaa.org/ |
#44
In my opinion, advancing a street cam a tad is all good, not just for stretch, it calms a too big cam a bit, it lowers the power band a bit.
1970 amc rebel 4-door, faded blue paint,290 emblems on car, 455 under the hood.Turbo 400,3.15 gear. Best so far 1/8 et,8.90 on street tires, Since that I have added 400 heads. I call it a rat sleeper. |
#45
http://forums.maxperformanceinc.com/...d.php?t=836358
#46
Thread Tools | |
Display Modes | |
