Old 02-11-2022, 09:52 PM
scott70's Avatar
scott70 scott70 is offline
It looks like saddle wasn't a recommended color for your color.
It would probably be very low volume use.
I believe the mint 70 judge with red interior also came from the oshawa plant.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 02-22-2022, 08:52 PM
Bermuda Blue Bermuda Blue is offline
Note that Oshawa build sheets are a small piece of paper listing the option codes. About 2" x 8". No dealer or customer order information is provided.
Old 02-23-2022, 09:30 PM
SD455DJ SD455DJ is offline
Like this...? This is from my 4-dr Tempest sedan that was ordered with the 400 2-bbl/TH400 (L65/M40) that was Oshawa built and sold in Stamford, CT.
Dennis
ID:	584777   Click image for larger version
ID:	584778   Click image for larger version
Name:	1970 Tempest 4-door - Dennis Jensen - draft copy_resized.JPG
ID:	584779   Click image for larger version
ID:	584780   Click image for larger version
Old 02-23-2022, 10:31 PM
scott70's Avatar
I did not know that. This was all I found under the back seat many years ago. I figured it started as the normal big build sheet and got eaten by probably mice but maybe it was the smaller Oshawa sheet.
Old 02-24-2022, 10:29 AM
That's the build sheet.
I see M21, G80 and L74 - those are the important ones!
Old 02-25-2022, 01:42 PM
Dennis:
Its interesting that your build sheet shows WS6. A well know code in Trans Am circles. WS6 was even used in the last generation Grand Prixs to indicate suspension components designed to improve high speed handling. In this case I believe WS6 gets you auto trans, power steering and power brakes.
Old 02-26-2022, 10:36 AM
scott70's Avatar
I also like the D98!
Old 02-26-2022, 11:20 AM
Dennis:
Ha! My first WS6 car...lol! I never noticed that.
Dennis
Old 02-26-2022, 07:51 PM
M21, G80 and L75 (don't see L74)
Dennis:
May have missed it but I don't see WS6 but Y96 is the Handling Package
The D98 stripe is sweet
My take on the Oshawa "build sheet" is:
D98 STRIPE, ACCENT
G80 AXLE POSITRACTION, LIMITED SLIP
GX2 AXLE REAR, 3.07 (or is it 3.31 RATIO) ??
JL2 BRAKES: DISC - FRONT - SINGLE PISTON CALIPER
J50 BRAKES: VACUUM POWER
L75 ENGINE 455-D- 4 Barrel
M21 TRANSMISSION: 4-SPEED MANUAL – CLOSE RATIO
N41 STEERING, POWER, VARIABLE RATIO
N98 WHEEL: RALLY II ROAD
PK5 G70-14 WIDE OVAL TIRES
U63 RADIO: AM PUSHBUTTON
U80 AUXILLIARY SPEAKER REAR
Y96 HANDLING PACKAGE
EWA = Engine WA Code
TDD = DD 4 Speed Close Ratio
AXU = Axle [XU] 3.31 - 12 Bolt Posi
TDP = Trim Colour ?
Old 02-26-2022, 09:12 PM
Don't see a TDD?
TDP is DP 4 speed for L75 engine.
USLD 34 34 - Mint Turquoise
255 - Saddle interior color
Old 02-27-2022, 06:54 AM
scott70's Avatar
And the specific DP(455 only) m21 code was probably just for the speedo gear or something?
I can't believe all these years and now finding out that Oshawa cars didn't have the full build sheets.
