Old 01-11-2008, 12:26 AM
Chris's Customs Chris's Customs is offline
Default Grill replacement/restoration 68 gto
Hey guys I am in need of help, restoring a 68 gto and need to do something about the grill, any suggestions
Old 01-11-2008, 01:34 AM
JLHarper's Avatar
JLHarper JLHarper is offline
I had alot of time in mine. I did a body over frame resto years back on my 68 convert.
Plastic prep, cleaning and light sanding was done before hand, not in that order.
I shot black slats first, taped and shot silver around inner edges.
I then hand painted with a high dollar artist brush (very thin and short hairs) the leading edge of the slats or veins in silver using a very slow stroke.
It was a royal pain, took a lot of patience but it looked really nice.
I spent way more then I should have on this car even with low miles, but it was fun and first car.
Pictures may not show details but slats leading edge were Silver, black inside slats and silver around inner circumfrance of grills.
The resto book has these paint codes I think.
PM me if you need any help.
ID:	117914   Click image for larger version
Old 01-11-2008, 12:44 PM
david400's Avatar
david400 david400 is offline
I was able to restore mine very easy. I cleaned them with a scrub pad and water ,
then went to the local hardware store and i no this mite be to easy for some of you guys but kraylon makes a spray paint that is designed to stick to plastic its called FUSION they have it in black and silver and the silver is a very close match, any way i painted them about 3 years ago now and the still look great.
Old 01-11-2008, 01:15 PM
68addict 68addict is offline
Dave,
Was the scrub pad steel wool or something milder?
Did you lay down the black first and then tape it off? If so, how long did you wait so as to avoid the paint peeling? Forgive the silly ? as I am not a paint expert. Thank you,
Anthony
Old 01-11-2008, 01:37 PM
robz's Avatar
robz robz is offline
Originally Posted by 68addict
Dave,
Anthony
Don't use any steel wool on plastic as it will damage/scratch it
Easiest way I found to remove all paint on plastic w/o any damage was using Easy-Off Oven Cleaner (Regular formula in a aerosol can)..Spray thoroughly, let soak inside plastic bag 24 hrs, hose off...Repeat if necessary..No scrubbing (or very little))..Especially simplified the '69 Hideaway covers as those tiny squares would have a been a pain to scrub individually.
Here are what my '69 Hideaway covers looked like as a result of cleaning...As well as 2 pics of painted Grilles/Hideaway covers
ID:	117950   Click image for larger version
ID:	117952   Click image for larger version
1969 GTO 400-4speed, H/T
1969 Grand Prix SJ
Old 01-11-2008, 02:14 PM
Robz thank you, great pictures and info. Yours came out great, and I have my 68 hide-a-ways to do up.
Old 01-11-2008, 02:47 PM
david400's Avatar
i used a nylon like pad just like you would use for cleaning dishes i also used some 400 grit wet/dry sand paper very lightly on some spots.
Old 01-11-2008, 02:50 PM
david400's Avatar
And yes i painted them black first then i nice tape job and then the silver,
Old 01-11-2008, 05:39 PM
thank you....It looks tedious but the results look great!
Old 01-11-2008, 08:53 PM
david400's Avatar
Heres a pic of mine i do have to say that i choose to paint the grills all black .And the silver is just around the outside.I think they look fine and on a black car they look even better IMO . Well crap it wont upload it ,to big of a file.
Old 01-12-2008, 01:11 AM
PaulatFast PaulatFast is offline
On my 68 we painted the silver first, on the fins as well. the outside was taped and the black was sprayed from the back, keeping the front edges silver. We were in a hurry and figured we could always go back and do them better, no need as they came out perfect.
Paul
FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first.
My site... needs updated-
www.fastrestorations.com
68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs!
