Old 02-16-2004, 05:13 PM
s.a.steel's Avatar
s.a.steel s.a.steel is offline
I put a brand new headlight switch in, but the dome light and courtesy lamps don't go out when the doors are closed. This just started recently. I've been doing alot to the dash of this car(79 TA), could I have pulled something loose?
s.a.steel's Avatar
Old 02-16-2004, 05:29 PM
wheelspin's Avatar
The dome and courtesy lights are turned on by rotating the headlight switch CCW. Rotating the switch to the right should turn them off unless there is a problem with the new switch.
Les
66 GTO Sport Coupe,455/trips,700r/2500stall,12bolt/3.08,1.79/13.01/104.5
68 GP daily driver and 2004 Route 66 Tour participant under restoration
Better lucky than good
Les Iden
Old 02-16-2004, 07:25 PM
s.a.steel's Avatar
This problem occurs with both the new and old switch. It has to be somewhere else in the circuit. Maybe I have a bad door pin?
Old 02-16-2004, 08:43 PM
wheelspin's Avatar
Manually test each door switch, the one that fails to turn the lights off needs replacing.
Les
Les Iden
Old 02-16-2004, 08:48 PM
mcbux's Avatar
mcbux mcbux is offline
The door switches only ground the circuit to the body. If you pinched a wire somewhere that would do it. Try tracing the door switch wires back to the harness they are comming from. There is a 70 GTO wiring diagram on page 2 of this forum. It might give you ideas of what and where to look. Sounds like something simple.
Old 03-04-2004, 01:15 PM
todd1qaz todd1qaz is offline
I have this problem on my 70 GTO convertible on the front courtesy lights. Afer not driving the car for about two weeks I tried to start it and the battery was dead. After replacing the battery I noticed that the front courtesy lights were on when the doors were shut. I replaced the headlight switch with no success. I am guessing that it is some type of grounding issue. The car is in storage now but I plan on getting to the heart of this matter sometime this spring.
If you come up with anything please let me know.
Old 03-04-2004, 06:27 PM
Tim W Tim W is offline
I is a grounding issue. Could be a switch or any connection. I had the same problem on my 79 TA. If you need a temporary resolution you can pull the dome light bulb which will prevent the other lights from turning on.
Old 03-05-2004, 08:55 PM
perry's Avatar
perry perry is offline
Try removing the door jamb switches one at a time if the lights go off when the switch is unscrewed and not touching the body than that switch is bad. If the switches test good than you must have a short to ground on one of the courtesy light circuits.
Perry
Gold Goat goes orbit orange at pontiacsonline.com
Old 03-07-2004, 07:54 PM
KVman389 KVman389 is offline
Sounds more like a door jamb swithch problem. That's the first p;ace I would check. Believe it or not, sometimes a simple lubrication to the switch will fix the problem. Second place I would look are the curtesy fixtures themselves, checking for shorts. After that, start tracing. These problems are usually simple in nature, but can be a pain in the @$$ at times. Hope this helps.
Remember when it was on a wing and a prayer? Now it's a wing and a fart can.
When I turn it on, wind it up, blow it out GTO
Old 03-08-2004, 07:15 PM
Dave Schiffers's Avatar
Dave Schiffers Dave Schiffers is offline
s.a.steel
Did you get it straightened out yet?
Dave
Old 03-08-2004, 07:37 PM
s.a.steel's Avatar
Have'nt had much time lately to get to it, so I pulled the bulbs. Next weekend I should have plenty of time to get the bottom of this. Thanks.
Old 03-08-2004, 07:58 PM
Judgemint's Avatar
Judgemint Judgemint is offline
I had this same problem in my Vette. Lights would stay on battery would be dead. It turned out to be a bad timmer, A small plastic box behind the glovebox for the court lights. about 15.00
Old 11-13-2004, 06:20 PM
DonColby DonColby is offline
Here's a strange twist. I noticed my cigarette lighter was unhooked on my 70 gto convertible. I plugged the wire in and my interior lights stayed on at all times. The lighter did not work. Unplugged the cigarette lighter and they work fine. Guess I won't start smoking.
