Old 05-04-2020, 10:28 PM
james66GTO james66GTO is offline
Default Looking for Ram Air IV Carb for AT (#7029270)
Starting a marriage project between a '69 242 convertible and a ram air IV block & heads. Car was originally an AT car and my block is an XP block so I'm staying with the automatic route. Would like to find an original intake manifold and #7029270 carb if possible as opposed to going the (considerably cheaper) aftermarket route. Thanks! Eric
Old 05-08-2020, 05:35 PM
acgwinn acgwinn is offline
Sent you a pm.
Old 05-21-2020, 02:23 AM
TTT
Old 06-14-2020, 02:54 AM
TTT
Old 07-09-2020, 10:35 AM
Default 1969 Ram Air IV Manifold & 7029270 Carb
Bump
Old 07-09-2020, 03:59 PM
69hardtop 69hardtop is offline
Still have this one, believe date stamp indicates it’s an SR carb ?
Old 07-09-2020, 11:53 PM
Default 7029270 Carb
Yes I believe so. I have a little time on this build so I'm trying to find an original one, thanks though ! Eric
Old 01-19-2021, 02:40 AM
Default 1969 Ram Air IV Manifold and 2709270 Carb
Still searching for an original setup, thanks. Eric
Old 01-19-2021, 04:46 PM
unruhjonny's Avatar
I am sure there are members here who have them;
Cliff often has desirable application number carbs that are not advertised here.
Keep your eyes peeled on eBay as they do come up from time to time.
If you find a potential candidate, I'm happy to help you discern if it's a restamp, ect - just shoot me an email (link in profile, no PM please)
It seems to me the average/reasonable asking price for an SR unit is around $800-$900;
The non-SR units are often about double that - just be lucky you're not looking for an OE non-SR m/t carb those get really pricey fast!!
1970 Formula 400
Old 01-19-2021, 11:28 PM
Thanks ! I appreciate the information and I'll take you up on your offer provided I actually locate one ! Eric
Old 01-20-2021, 01:46 AM
3goats's Avatar
3goats 3goats is offline
There is one on Kijiji in Winnipeg MB, listed is a complete aftermarket ram air set up and s 270 carb. Doesn't mention if an Sr or original,
FYI
Old 01-20-2021, 06:41 PM
Thanks, I'll check it out, Eric
Old 01-20-2021, 07:14 PM
unruhjonny's Avatar
https://www.kijiji.ca/v-other-auto-p...bly/1546868911
That's the ad;
The seller doesn't indicate the species(?) of carb - as a matter of fact, I find it odd that the most valuable part has no detailed pictures;
But for an American buyer who might be interested in the extra parts, this could be a deal;
If my math is correct $2,400cnd is about $1,800usd.
1970 Formula 400
Old 01-21-2021, 12:06 AM
It turned out to be a modified carb that he bought on eBay six years ago. The main body looked correct but the air horn didn’t
Old 01-21-2021, 12:17 AM
unruhjonny's Avatar
There was a member here in BC selling one a couple years ago, I believe it too was a service replacement unit though.
1970 Formula 400
Old 01-22-2021, 12:02 AM
3goats's Avatar
Hello Eric
Found you another one. Its on kijiji under pontiac engines for sale in Calgary AB.
Sorry I don't know how to paste the ad. Maybe unruhjonny will again. Thanks
Old 01-22-2021, 10:50 AM
unruhjonny's Avatar
In Calgary!?
that's right here!!
lol
That ad is a member here;
Message member "birdsandgoats".
1970 Formula 400
Old 01-22-2021, 12:02 PM
Thanks for the lead ! I’ve reached out to the seller and waiting for a response. I have to say, I wonder if there’s any original, unaltered ram air carbs out there anymore. In my searching it seems you can find carburetors with the original main bodies but either the airhorn or throttle bodies (or both) have been changed. You would think the body would be the hard part to find (!)
Old 01-22-2021, 12:22 PM
unruhjonny's Avatar
on there are original ones out there still.
They are just not cheap.
The real leg work is in knowing what are the correct casting numbers and physical traits of them, because as an example, in the case of the throttlebody there are two distinct variations of the same casting number - and they were machined one of two ways depending on the intended application;
Then there are a few (as far as '9270 carbs are concerned) OE vs SR differences.
But really, they are the sum of the parts, and it has been pointed out before, virtually any Quadrajet can be modified (if done properly) to run just like a 750cfm '270.
The only real problem are the unscrupulous individuals who take a carb then with deceit as their intent, renumber it and try to present it as something it wasn't with little regard to anything other than getting top dollar because of the stamped number - this can often been seen with ebay units.
1970 Formula 400
Old 01-22-2021, 03:38 PM
Joe's Garage Joe's Garage is offline
Default James - clear your PMs
Tried to send you a lead on a carb, but can't get it to you.........your box is full........
