Old 11-06-2020, 12:47 PM
getmygoat's Avatar
Default Game Changer 5-speed from Tremec
No more cutting for a-bodies! This is awesome!
A more mainstream replacement for the legend, which was unavailable and under capitalized.
https://shiftsst.com/tremec-tkx-5-speed
The Following User Says Thank You to getmygoat For This Useful Post:
Old 11-06-2020, 12:51 PM
Stuart's Avatar
Stuart Stuart is offline
Good for 600 ft-lbs of torque, too. I've read it costs under $3,000 but don't know details about that.
Old 11-06-2020, 01:52 PM
65madgoat's Avatar
Yeah! Finally made a TKO case that fits.
Otherwise here is what you had to do to fit a Tremec TKO in an A-body Lemans GTO:
https://www.youtube.com/watch?v=Uwie8oypJWY
Now get on it purists and drive your car. Won't regret it. Ask anyone and they will tell you that a trans swap is the best thing they ever did. And now it can be done without mods.
Old 11-06-2020, 02:15 PM
Tarl Tarl is offline
Wish they had these when I cut the top off my transmission tunnel, and got a sunburn welding in my malformed home made higher tunnel.
The Following User Says Thank You to Tarl For This Useful Post:
Old 11-09-2020, 11:56 AM
The Champ's Avatar
I sent in a request for quote for my '64.
Including shifter, driveshaft, fluids and delivery it's just a tick under $4300.00. This is for the 3.27 first gear and the .72 overdrive.
The Following User Says Thank You to The Champ For This Useful Post:
Old 11-09-2020, 12:03 PM
scott70's Avatar
scott70 scott70 is offline
If my original muncie ever became unfixable this is what Id be getting.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
The Following User Says Thank You to scott70 For This Useful Post:
Old 11-09-2020, 02:26 PM
rwfisher's Avatar
rwfisher rwfisher is offline
The Email I received back from them indicated when a 1st gen F- body kit would be available but no indication if cutting required.. We'll have to sit back and see.....
Old 11-09-2020, 05:58 PM
nas t eh nas t eh is offline
I'm guessing the Richmond 5 speed(Updated Doug Nash4+1) does not fit A bodies or has some other concerns?
https://www.richmondgear.com/wp-cont...hmond/RG22.pdf
At $2600 with a shifter seems like an option.
Old 11-09-2020, 06:23 PM
mgarblik mgarblik is offline
I love the fact that the Richmond transmission can be taken apart and rebuilt with a socket set, screwdriver and a hammer. Really simple. Wonder what the fitment issues would be in an old B body like a 62 Catalina? The price is very attractive as well. I sent off for an estimate on the TKX as well. Both are interesting.
Old 11-09-2020, 08:44 PM
Did a little looking around after your post. $3650.00 seems to be the "going price" for this transmission. Is the $2650.00 a real price and from who? They are in the game for that price. $3650.00, not so much. Thanks .
Old 11-09-2020, 10:56 PM
Maybe I got it wrong and saw what I wanted (dreamed it was) as I was just looking a few days ago.
Had another look and I see Jegs has all three 1st gear ratios available but the 3.08 1st gear version “C” is just under $3100 instead of 3600 for the other two.
Old 11-09-2020, 11:12 PM
getmygoat's Avatar
My understanding is there is nothing available prior to the TKX and the Legend that doesn't require cutting the tunnel.
I believe there might be an automatic overdrive or two that will bolt in, but no manuals.
Old 11-09-2020, 11:49 PM
tom s tom s is offline
Standard TKOs fit a first gen bird with no cutting.Tom
Old 11-10-2020, 01:32 AM
Ben M.'s Avatar
Ben M. Ben M. is offline
I'll believe it once people actually order them AND receive them in a timely manner... I'm a little cynical after the drama over the last time...
Old 11-10-2020, 04:10 AM
64speed's Avatar
64speed 64speed is offline
I did not cut the tunnel except for the shifter hole in my 64 with the TKO600 Extreme with the streamlined case from American Powertrain. Now the only caveat is all my body bushings are new and the car sits as it should
Old 11-11-2020, 03:54 AM
lust4speed's Avatar
We've installed the Silver Sport TKO-600 in two '67 GTO's and neither had to have the tunnel cut. One car required nothing for the trans to slip in place, and the other tunnel needed two areas the size of quarters tapped away from the top edge corner of the trans. Might or might not have touched, but too easy to do without the trans in the car.
Problem with the Richmond is that the shifter porch has to be moved 3" to the rear which means the console is either left out or also slid the 3" back.
The photos of the TKS 5-Speed case look great and I'd opt for this new design. The 7,500 RPM shifting limit far surpasses the old 6,000 RPM limit of the standard TKO-600. I opted for the carbon fiber lined synchro's and that was only advertised as 6,500+ RPM. Most of us won't get anywhere near the new limit, but still a nice improvement.
Mick Batson
Old 11-11-2020, 10:43 AM
I sent away for what they call a "quick quote" for the trans and installation pieces. Had a very detailed 2 page quote sent back in 2 days. Total cost would be $4165.00 including shipping. About $2800.00 for the trans alone. $1100.00 for all the installation parts. Then shipping. They indicated no modifications would be needed for the tunnel and shift porch. Seem to be professional and detail oriented. BTW, this was for a 62 Catalina, Bench seat.
Old 11-11-2020, 04:08 PM
Gator67's Avatar
Gator67 Gator67 is offline
I’ve been thinking about putting a 5-speed in my ‘67, and this seems to have addressed everything that was holding me back. If it fits A and F bodies without cutting the floor and it shifts as nicely as the T56, they’re going to sell a lot of these.
Old 11-12-2020, 11:08 AM
RA462's Avatar
RA462 RA462 is offline
So is this all the guts from a TKO600 in a different case?
Todd Sedlmeier
Who ever thought pinewood derby cars would lead to this!
October 2004 HPP Shootout participate
http://www.highperformancepontiac.co...out/index.html
86 Grand Prix
535 High Port 8.93 @ 153
65 GTO
433 High Port 12.04 @ 113
Old 11-12-2020, 12:34 PM
misterp266's Avatar
$1100. for installation parts? Seems like a lot, what do you get? I have a Richmond 5 speed going in my ‘63 Catalina Safari with bench seat and I know the tunnel needs to be cut. The only thing I don’t like is the shifter gets moved back about three more inches buy I’m 6’3” and the seat will be all the way back anyway. I’m converting from an automatic so there’s no porch in it now.
" Darksiders Rule "
