<74-75> Firebird sheet metal questions
Has anyone put 70-73 quarters, rear window and tail panel sheet metal on a 75-78 successfully? It would appear to be a possibility and probably gas tanks and hardware need changing, trunk floor modified(?), maybe some custom work or used pieces for the window channel, etc.
I would also be considering replacement of the inner rear wheel wells with wider ones to put more rubber under the car as part of the project.
