Old 04-02-2024, 11:44 AM
Mbeck Mbeck is offline
Default Air cleaner assembly/pan for quadrajet
I've got a R4-4MV Quadrajet carb and am in need of the air cleaner assembly. Can anyone advise on the correct pan/assembly?
Old 04-02-2024, 12:12 PM
It seems like it needs a spacer ring?
Old 04-02-2024, 01:18 PM
Kenth's Avatar
Kenth Kenth is offline
No spacer ring needed with an original Quadrajet air cleaner assembly.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 04-02-2024, 02:40 PM
What year & model of Pontiac are you working on?
Old 04-02-2024, 02:55 PM
steve25 steve25 is offline
If I recall right only Chevy and GMC pickup trucks used about a 2” tall metal spacer ring.
Old 04-02-2024, 05:18 PM
I found a dual snorkel that fit perfect. Yet another issue that over-analyzed.
Old 04-02-2024, 10:46 PM
Half-Inch Stud's Avatar
Half-Inch Stud Half-Inch Stud is online now
...collected a bunch of them Q-JET AIr Cleaner base Spacers; 1" and 2" i tink. Probably worth power increas whenever they can be used.
