Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 10-15-2017, 03:59 PM
428RA4's Avatar
428RA4 428RA4 is offline
Default RAM AIR V HEADS - for sale - GM -
Ram Air V heads for sale. Original GM castings. Pressure checked and maged. Aftermarket titanium valves, sprigs, keepers. Comes with pushrod guides and I believe valve guides. Have to dig the parts out. Does have a few air foils, but not a complete set. Lets discuss....
10K
mornellas13@gmail.com
Old 10-15-2017, 06:30 PM
428RA4's Avatar
Pictures attached.
ID:	465459   Click image for larger version
ID:	465460   Click image for larger version
ID:	465461   Click image for larger version
ID:	465462   Click image for larger version
Old 10-15-2017, 06:33 PM
428RA4's Avatar
more
ID:	465464   Click image for larger version
ID:	465465   Click image for larger version
ID:	465466   Click image for larger version
ID:	465467   Click image for larger version
Old 10-15-2017, 06:36 PM
428RA4's Avatar
Intake is not included.
ID:	465469   Click image for larger version
ID:	465470   Click image for larger version
ID:	465471   Click image for larger version
ID:	465472   Click image for larger version
Old 10-15-2017, 06:48 PM
tom s tom s is offline
Mike,I have foils if you or the new owner needs them.Tom
Old 10-15-2017, 06:59 PM
428RA4's Avatar
Got it,
I was thinking the same.
Old 10-15-2017, 07:51 PM
71 T/A 71 T/A is offline
Any ram air v intakes for sale too?
How many cc's are the heads' chambers?
Old 10-15-2017, 08:48 PM
428RA4's Avatar
Tom has spoken for the Dual Quad intake. I don't have a single 4 barrel intake, but I believe Tom may be able to assist. I sold my last NOS 4 barrel intake 3 years ago.I may have other important hardware for the factory intake in the garage though.
These heads have not been decked so they should be 78 CC's.
Old 10-15-2017, 09:03 PM
428RA4's Avatar
Here is the eBay listing...
http://www.ebay.com/itm/263264807385...84.m1558.l2648
Old 10-15-2017, 09:40 PM
muscle_collector's Avatar
are they 44 castings or DS # or nothing?? I also am looking for a 400 intake.
Old 10-15-2017, 09:55 PM
428RA4's Avatar
the casting area is blank and is the only set I've had like this. I've had Developmental and 44 castings, but this is the only set I've had that are blank
ID:	465484   Click image for larger version
Old 10-16-2017, 08:08 AM
Aluminum Chief's Avatar
Aluminum Chief Aluminum Chief is offline
Default V
Interested in the heat riser and oil drippers if you have. Also interested in the 2x4 Intake behind Tom. Thanks KC
Old 10-16-2017, 11:21 AM
428RA4's Avatar
Hi KC -
The heat riser that you see in one of the shots is a hand made item and not an original. I have more then a few pairs made. I can throw them in with the sale. Just talked to Tom and it sounds like he is going through with the purchase of my intake. I'm sure he'll have something available for you shortly once he gets mine.
I don't have any oil droppers for this engine. Let me know soon if you're serious about the heads as I have a few bites already.
thanks
mike
Old 10-16-2017, 01:16 PM
Default V
Mike, I am not interested in the heads, interested in a heat riser if you have a spare to sell, pulley`s and a square coil if available. What intake hardware were you referring to in another post? Thanks Ken.
Old 10-16-2017, 01:33 PM
428RA4's Avatar
I can sell you a set of heat risers. I think I may have two sets left.
I've built a RA V factory stock top end to fine detail and have extra parts if interested. Things like bolts, brackets, washers, etc...
Contact me here if interested.
Old 03-01-2020, 08:53 PM
indiangiver 68's Avatar
indiangiver 68 indiangiver 68 is offline
I am interested in some of the bolts-brackets . Trying to do the factory look
Old 03-01-2020, 09:59 PM
Default Almost three year old thread
OP hasn't logged in since 2017......
You might want to try emailing directly.
Good luck.
Old 03-01-2020, 11:05 PM
Talked to Mike,he has no clue what he has left if anything.Tom
