Old 09-09-2004, 10:33 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
I wonder how Motornoggin is coming along with his Yellow 4 banger?? Last I heard, he was having a slow time getting his Holly Projection adjusted. Anyone heard from him??
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 09-10-2004, 01:18 PM
sdbob sdbob is offline
White Warrior;I remember John was running comp eliminator. The dragster had carbs and he had a problem with the vibration and carb floats. He was trying 'floatless' carbs. Ijust called him ,haven't talked to him in few years. he wasn't home. Also I remember a guy running a Jeep with a 4 in hill climbing ,never talked to him I think his name was Andy Bassistta from N.J.He used carbs and home built tunnel ram. If you are interested when I talk to John I'll see if he has an intake,then you two can work out the details.
Old 09-20-2004, 12:48 PM
White Warrior White Warrior is offline
Thanks,SD Bob. I may have a vibration issue,too. Had the car out last weekend and even tho it ran a little quicker than the first time [12.63 vs 12.78] it won't pull above 6500 rpm. See if you can get me some phone#s for these 4 banger experts. Thanks.
Old 09-30-2004, 02:24 PM
Just got your message. I have been working. I will get his number to you. He has no parts left.
Old 10-21-2004, 01:59 PM
White Warrior :Check the private message I sent you.Tell John I told you to call. Bob
