have finished up prototype brackets for 1961-63 Lemans. They use 82-92 Firebird calipers and pads, along with 1985-90 Cadillac Fleetwood rotors. These rotors are small enough to tuck in later 14" disc rims. These bracket run $95 for PY people.
I'm interested in buying a set when can you ship a set?
anytime, have them in stock now..
is there a willwood brake kit or other liteweight kit that will work with these?
there is but you will need a adapter,there were some avail. from a member of this site,not sure if he has any left.It uses a Wilwood ford 9in rear setup.Tom
excuse my ignorance,but are these for the front or a solid axle rearend?
These are for the front. Replaces the stock drums & backing plates.
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
ok thanx,Scarebird you have mail
Scarebird do still have a website?
If so please post it. as i will have ??? |
Hi
The cadillac rotors are they front or rear rotors? |
front.
Thanks!!!
I hope they will have a few sets of these brakets at Carlisle. |
update- I picked up a few Ford T-bird master cylinders, these are nice aluminum pieces with right hand fluid ports, and will see how they fit and work in the 62. they have 21mm bores, slightly smaller than the manual single lung stock unit, so pedal effort should be about the same.
what is the bolt pattern for the rotors?thanks,chris
5 on 4-1/2", as per stock.
