Old 11-07-2004, 07:58 AM
oldinjun oldinjun is offline
Tom S. , or anyone else know of a brand & part # for a front coil spring I can use to lower the front end of my '63 LeMans? I don't like the idea of cutting the stock springs, and I'm looking for one that sits lower, plus a spring rate that will work well in a drag car application. Any ideas? Thanks!
I no longer want to die mowing the lawn!
Old 11-07-2004, 08:55 AM
tom s tom s is offline
when I put the 421 and a front trans in my coupe,I contacted a spring dist. that I found in Hemmings.I ordered 63 tempest V8 station wagon plus 200 lbs and they came out perfect.If you have V8 springs now and you want it lowered I would just order 4cyc springs.They should be where you want to be.Tom
Old 11-07-2004, 12:24 PM
Thanks Tom, I was thinking of that too. The car was originally a 326 car.
