Old 09-03-2004, 08:49 PM
have finished up prototype brackets for 1961-63 Lemans. They use 82-92 Firebird calipers and pads, along with 1985-90 Cadillac Fleetwood rotors. These rotors are small enough to tuck in later 14" disc rims. These bracket run $95 for PY people.
Old 09-04-2004, 12:46 PM
63lemanster's Avatar
63lemanster 63lemanster is offline
I'm interested in buying a set when can you ship a set?
Old 09-04-2004, 01:43 PM
anytime, have them in stock now..
Old 09-04-2004, 08:57 PM
is there a willwood brake kit or other liteweight kit that will work with these?
Old 09-04-2004, 09:15 PM
tom s tom s is offline
there is but you will need a adapter,there were some avail. from a member of this site,not sure if he has any left.It uses a Wilwood ford 9in rear setup.Tom
Old 09-04-2004, 11:30 PM
excuse my ignorance,but are these for the front or a solid axle rearend?
Old 09-05-2004, 12:43 AM
mechanickeith's Avatar
These are for the front. Replaces the stock drums & backing plates.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 09-05-2004, 09:27 AM
ok thanx,Scarebird you have mail
Old 09-07-2004, 03:43 PM
Mark W's Avatar
Mark W Mark W is offline
Scarebird do still have a website?
If so please post it. as i will have ???
Old 09-07-2004, 05:51 PM
Mark, just shoot me an e-mail:
res086iw@verizon.net
Old 09-13-2004, 03:14 PM
pontbil pontbil is offline
Hi
The cadillac rotors are they front or rear rotors?
Old 09-15-2004, 10:16 PM
front.
Old 09-16-2004, 02:23 PM
Thanks!!!
I hope they will have a few sets of these brakets at Carlisle.
Old 10-31-2004, 06:51 PM
update- I picked up a few Ford T-bird master cylinders, these are nice aluminum pieces with right hand fluid ports, and will see how they fit and work in the 62. they have 21mm bores, slightly smaller than the manual single lung stock unit, so pedal effort should be about the same.
Old 11-01-2004, 01:58 PM
higgenslake higgenslake is offline
what is the bolt pattern for the rotors?thanks,chris
Old 11-02-2004, 10:10 AM
5 on 4-1/2", as per stock.
