Old 04-24-2016, 08:04 PM
Stuart's Avatar
Stuart Stuart is offline
As mentioned above, try Scarebird for your 1956 Pontiac.
Old 04-24-2016, 08:33 PM
torbay56catalina torbay56catalina is offline
thanks I checked with Scarebird, the only listing they have is for the 55-57 chieftain not sure if that will fit ,I sent an email off to them and asked that question. do you know if the chieftain has ball joints , or kingpins like the catalina?
Old 04-24-2016, 09:31 PM
Depends if it is a Canadian car or not. Canadian cars are essentially Chevrolet running gear. If it is a true Pontiac then yes we can help.
Old 04-25-2016, 04:56 AM
the owner says it is American , I will have to look at the serial # and tag . thanks
Old 04-25-2016, 09:55 AM
Stuart's Avatar
Prior to 1959 I believe the Catalina was just the name they used for the hardtop version of the Chieftan, so the suspension and brakes should be the same.
Old 04-25-2016, 10:56 AM
pfilean's Avatar
pfilean pfilean is offline
Parts book says steering knuckle 55 all with L & R versions. 56-57 all with L & R versions. 58 are different part numbers than above and fit both sides. Picture for 58 looks like ball joints so 58 is probably the change over year. SO if you are US build you should be good.
