Old 01-14-2022, 04:03 PM
Chris65LeMans's Avatar
Default Need Oil Filter for a '65 LeMans with headers.
Getting everything together now. My car is a 4 speed, has Doug's headers and has a Lakewood bell housing.
The supplied oil filter will fit in it's spot, but we can't get it up there.
My choices are:
1. Find a narrower oil filter.
2. Set up remote oil filter.
3. Unbolt the oil filter housing and pull it out the top every time I do an oil change. (Been there, don't want to do that again.)
I like to keep things simple, so my preferred solution is #1. What do y'all think?
Name:	In Place - Need Oil Filter Cropped.jpg
Old 01-14-2022, 04:21 PM
Steve C. Steve C. is offline
Check if the WIX 51045 will work.
https://www.finditparts.com/products...-filters-51045
Old information here:
Old 01-14-2022, 04:31 PM
Mike Davis's Avatar
Best one right here. Been running these for about 4 years now. Nice to be able to inspect for particles and wash and go.
https://kandpengineering.com/product/S16/
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 01-14-2022, 04:45 PM
Gary H's Avatar
Gary H Gary H is online now
I have run into this multiple times on customer's cars that have D port Doug's headers and a 4 manual transmission. All the cars were using a factory bell housings though. What I have done is modifying the bell housing so that I can get a full size filter in there. I take a grinder and remove material till I can get it through the opening.
Old 01-14-2022, 05:16 PM
tom s tom s is offline
The Exact reason I tell guys with true street cars to run RA manifolds over headers.FWIW,Tom
The Following 3 Users Say Thank You to tom s For This Useful Post:
Old 01-14-2022, 05:30 PM
i82much's Avatar
i82much i82much is offline
I have a 65 four speed with round port doug's headers and mcleod bell. I run the HP2006 filter because the nut on the bottom makes life way easier.
When I had previous header clearance issues I ran a System-1 210 series "Spin On" Billet oil filter similar to what Mike posted. I used to get badgered on occasions because it had only a 30 micron screen.
Possibly this might be of help:
https://pontiacstreetperformance.com...iladapter.html
Old 01-14-2022, 05:33 PM
TransAm 474's Avatar
TransAm 474 TransAm 474 is online now
We have always used the Wix 51045 for header applications that doesn't have any room for a standard sized filter.
1978 Trans Am
Pump Gas 461 Stroker
Old 01-14-2022, 07:48 PM
64speed's Avatar
64speed 64speed is offline
Wix 51258, or Baldwin B39
Old 01-14-2022, 08:14 PM
ponjohn's Avatar
ponjohn ponjohn is offline
What do you wash it with?
Old 01-14-2022, 08:25 PM
Wix 51258
That's considered the 'regular' size filter and similar to the old Delco PF-24
He needs to evaluate it's dimensions.
Old 01-14-2022, 09:08 PM
64speed's Avatar
51258 is on my 64 with Dougs round ports and the aftermarket bellhousing that has a starter kickout on each side
Old 01-14-2022, 09:10 PM
ZeGermanHam's Avatar
Chris: I'm not sure which filter you're currently working with, but for reference if it helps, I have a Wix 51258 on the desk in front of me. It measures exactly 4-1/4" tall and 3-5/8" wide. Those are the real-life measurements, which vary slightly from the official published numbers. I'm hoping to use this filter in my '66 with Doug's d-port headers - although I have an automatic with stock TH400 bellhousing. Time will tell.
I agree, but good luck getting your hands on a pair of RA manifolds these days, though. They've been on backorder at RARE for over a year.
1998 BMW 328is (track rat)
Old 01-14-2022, 10:16 PM
D ports have not been a big issue for a bodies or 2nd gen birds or first gens.Tom
Old 01-14-2022, 10:46 PM
If you're referring to D-port RA manifolds, that was not my experience for my 66 A-body. I had an order in with RARE for a set of D-port manifolds for a very long time last year. Paul is/was unable to get LH manifold castings for D-ports, but he continued to tell me for many months that he was getting more in "next week". That never happened, so I had to bail on the order. I think there are a few other folks here who hit the same wall as me with getting D-port RA manifolds from RARE. Maybe the D-port RA manifolds sold by other companies are more readily available - no clue on that.
Old 01-15-2022, 09:53 AM
ANDYA ANDYA is offline
It's hard to tell by the angle of the picture in the first post, but what about trying the Firebird long branch filter adapter. It will tilt the filter to the 7-8 o clock position and may clear a larger filter.
Old 01-15-2022, 09:56 AM
Gary H's Avatar
Tom, I've never had a problem with an automatic equipped 64-67 A body with D port Doug headers, but manual transmission cars with the factory bell housings have been the issue. I have had to partially remove the passenger side starter "ear" on the bellhousing so I can get the filters in there. Surprisingly, round port headers for the same car don't have the issue. Only D port ones. Weird!
Old 01-15-2022, 10:27 AM
Agreed. I gave up calling them for an update even. Waste of time.
Old 01-15-2022, 10:36 AM
PunchT37's Avatar
PunchT37 PunchT37 is online now
Wix 51522 or AC PF61 [not 61E].
Old 01-15-2022, 03:47 PM
Mike Davis's Avatar
Brake Cleaner. Been running these on a few street cars and on my race car. Nice to be able to open it up so easily and inspect for debris.
The Following User Says Thank You to Mike Davis For This Useful Post:
Thread Tools
Display Modes
