Old 01-18-2022, 02:04 PM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is offline
Default SFI power bond damper
Anyone have experience with these you would share? I’m building an engine around 750-800 HP then going to spray another 250+ Nitrous. Should I just go ATI instead?
Old 01-18-2022, 04:57 PM
oldblueponcho's Avatar
oldblueponcho oldblueponcho is offline
I have a SFI Power Bond damper i bought about 15 years ago. It's performed flawlessly. But my engine only makes 521 HP crankshaft.
Some Fear, Because if you've never been afraid- just a little. You're obviously not going as fast as you could be.
Old 01-18-2022, 06:05 PM
grandam1979 grandam1979 is offline
I’m using 2 of them on a couple of 455 base engines 550-600 hp. For the hp your wanting to go I think I would get something better. My2¢
Old 01-18-2022, 07:35 PM
chuckies76ta's Avatar
My understanding is that once you get into the higher HP use an ATI balancer. The ATI balancer will move the pulley out a bit futher, and also I had to clear the timing cover a bit. Also, they use 3 bolt pulley with them.
I've used 2 SFI powerbond balancers on 600 hp for years with no issues.
Old 01-19-2022, 06:18 PM
mgarblik mgarblik is offline
I am going to be running a Power Bond damper on my current build of 500-550 HP. It looks like a nice balancer. But I don't think I would trust it at 1000 HP which is what your talking about. I know for a fact that the ATI balancers we ran on the Grocery Getter were flawless for 18 years at over 1000 HP. Never requiring anything. I know the cost and lack of a 4 bolt pulley attachment is an issue for some. But they are the best of the best. No experience with PowerBond at the power level you will be running.
Old 01-19-2022, 06:25 PM
mchell's Avatar
mchell mchell is offline
I went with a Romac on my current build…. Seems like a decent unit. It did require some fitting as it was too tight on my aftermarket crank
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 01-19-2022, 09:23 PM
Nacs Fab's Avatar
Guys there is a fella selling power bond dampers on marketplace for $45. Not sure if it’s legit or what.
Old 01-20-2022, 09:48 AM
Are you gonna buy one and put it on your 800 hp engine?
This is gonna sound condescending but why would you post that? You ask a legit question and people stepped up to answer your question with real world experience. Anybody with any experience wouldn't even look at a $45. balancer. They would already know it's a pos. Sorry if I hurt your feelings but focus on the topic, and maybe address your audience that are trying to help you make a wise decision..
Butler balancers for your reference, and what they cost from a reputable company.
https://butlerperformance.com/c-1234...s-dampers.html
Old 01-20-2022, 10:28 AM
Nacs Fab's Avatar
Yeah I was just posting up for others who may want to buy it. I’m going with ATI based off the information you all gave me.
The Following 2 Users Say Thank You to Nacs Fab For This Useful Post:
Old 01-20-2022, 11:10 AM
They sell one that’s not sfi maybe that’s what you looked at?
Old 01-20-2022, 12:17 PM
Nacs Fab's Avatar
No the one I looked at was SFI. Geez guys
Old 01-20-2022, 02:40 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My ATI I bought in the late 80s early 90s. It is two piece and does take a 3 bolt Chevy pattern. I had to shorten the hub where it hits the crank gear as it kicked the pulley out 1/8" perfect now. I also had to enlarge the crank bolt recess to take a normal crank bolt washer as it was too small..
I found a Chevy pulley support ring that goes outside the pulleys like our Pontiacs have to use as a template for the holes. RARE can drill their aluminum pulleys for both patterns.
I think the Power Bond have an SFI and a non SFI one.,sounds cheap for an SFI one.
Skip Fix
Old 01-20-2022, 02:58 PM
Nacs Fab's Avatar
https://www.facebook.com/marketplace...6018002616681/
Old 01-20-2022, 03:17 PM
That’s the one 1056 if those are not blems or something like that it’s a great deal. When I got a couple for $130.00 each I thought that was a great deal.
Old 01-20-2022, 03:20 PM
Dragncar Dragncar is offline
There is a difference between China SFI and USA made SFI parts. I would not put a Power Bond on a go cart.
ATI 3 bolt or a BHJ 4 bolt.
Old 01-20-2022, 03:40 PM
Nacs Fab's Avatar
Yessir I’m going ATI
Old 01-20-2022, 07:52 PM
dragracerx2813's Avatar
dragracerx2813 dragracerx2813 is offline
Power bond is made in Australia not China. Even says so on the box. They are a division of Dayco. Day o headquarters are in Michigan.
Old 01-21-2022, 04:50 PM
I have had a Power Bond and PP balancer over the years, non SFI. Both moved, junk IMO. Maybe their SFI ones are better but they left a bad impression.
Saving a few bucks is not worth your engine. I ended up putting my stock one on the 455 that Dan Whitmore inspected, degreed, added timing marks to and sleeved the seal surface. Still on the engine.
Old 01-21-2022, 05:09 PM
It's always a good idea to degree-in the balancer, no matter what brand, even ATI. I then put a small witness mark on the hub and outer ring to check later after use. Power Bond looks like a stock style balancer and seems to have a decent reputation. But I mark them just in case.
Old 01-21-2022, 06:04 PM
I never said they weren’t junk. Just that the SFI ones are from China. I am sure they are okay in lower horse power applications. But I would try them on a engine making serious power. I haven’t bought a ATI balancer in years. But I am pretty sure they aren’t American made anymore.
