#61
OMG my back is killing me lol. i finished we actually started buffing and polishing the rest of car. all went well except i ran into a problem with my pass side rear qtr. I had a run there, i wet sanded it out the other day but when i went to polish it i could see it again. so i grabbed and old 2000 grit and a wet sponge and started to sand it out. well i had the radio up and apparently there was a grit of sand in there and put a bunch of scratches in the paint. soooo, i turned down the radio and started to wet sand the scratches out....thats when i hit base coat. damn. so, i guess the good thing is that i can simply re roll the rear qtr, wetsand and repolish..which is what i will do later. the rest of the car looks pretty good. i think i will go back over it again with the polish and some new foam pads. here is a pick of the good qtr.
ok,photo upload failed. i guess i ll try later,
Vic in SoCal. Follow me on Instagram- Cloud9orbust 66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi. My T56 Install My Turbo Build My Vortech Supercharger Build Hyd Throw out bearing Misc Build Pics May the Karma Gods meet you half way.... |
#62
#63
Wow, that looks great. These posts keep making me regret buying all that expensive paint just to mess it up lol.
1969 GTO. Full rotisserie restoration "completed" in 2014. 5.3L "LM7", TKO600, 3.55's out back. Big cam coming soon. |
#64
I agree. That looks great, nice and straight, too. I'm betting that paint job will last quite a while if taken care of. A lot of labor, but looks better than a ton of high-dollar jobs I've seen.
#65
What about all those tight areas like inside the trunk seal lip, the inside corners of the tail panel, door hinge area, etc.? How did you approach those?
Greg Reid Palmetto, Georgia |
#66
i rattle canned all the door jambs, trunk lid jamb, hood jambs, tail lights recesses with over spray to the area to be rolled. then when i wet sanded it took off the over spray where it is to be rolled on the exterior. i ll run out there and snap a shot..
#67
Ah, makes sense. Just used the same Rustoleum gloss black, but the rattle can version.
#68
This is hard to believe ... looks AWESOME!!
#69
yes, in fact i actually sprayed the rear tail lights. they match perfectly. I tried to take some pics but it was too dark in the garage, i ll try tomorrow.
#70
You guys should try using an airless paint srayer you can rent from most paint stores.
comes out really well. You can also use marine paints like awl grip that work really well,. Looks awsome!
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
#71
un bee leev uble..
I wanna do this... I dont know why but it just seems appropriate... Looks GREAT!
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
#72
I was looking at the wagner spray guns lol...but i had success with the low tech (and less expensive) rollers so i went with that....maybe i ll bump up my game to a wagner on my next paint job I wonder if you can shoot a metal flake with a wagner?
#73
Does Rustoleum even make a non aerosol metalflake?
#74
well, i was playing around with mixing some Rustoleum Aluminum color with black. im thinking it would work if you could get the ratio right. im just not sure how well it would polish up. and also the flakes are very fine
#75
Might not work that well,same principle as a single stage metal flake. If you sand and buff metalic single stage it burnishes the metalics causing a blotchy appearance.
1969 GTO street strip project 11.1 forged 461, highport heads 1995 Trans-am 420 ci sb 14:1 compression 9"ford 9.89@132 1.34 60ft SOLD! |
#76
How many coats again is that black?? Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
#77
It looks excellent. The queston is how long will it last with all the work you put into it. If you invested in a compressor, you would be able to use real automotive paint. If you added up the cost of all the supplies it might not be such a bargan. Black rustoleum might last 6 months out in the AZ sun before it starts to fade. You could have painted 4 cars with AU with the amount of work it takes to do rustoleum.
#78
You can spray metalics like a pro with even the cheapest HF gravity feed gun they sell if you have a compressor. It only takes a few dollars worth of sand paper if the sand paper is not getting gummed from the paint. Black paint is on the bottom tier as far as paint cost go. It can also be bought as fleet paint. http://www.smartshoppersinc.com
#79
I put some of this paint on my truck over 5 years ago. It can still be polished.
#80
I think the idea was to get some paint on the car as quickly as possible and still have it look decent... at a very low cost.
Looks like it worked. And if anyone wants to change the color later, boom, just strip it and start over. |
