Old 08-08-2020, 09:20 AM
RA1John RA1John is offline
Default Heater Core Tubes Seal (w/Air Conditioning)
Trying to confirm what type of seal was used between Heater Core and Firewall around the Inlet/Outlet Tubes on a factory A/C car.
When I disassembled my Dad's '64 to fix a leaky Heater Core, I didn't find any evidence of a Seal. This is pretty much an all original, CA car. Original Heater Core.
I realize that NON-A/C cars had a formed foam Seal around the tubes but I can't find anything showing what was used on A/C cars.
Suggestions, references?
Thanks!
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
Old 08-08-2020, 09:22 AM
John
John 14:6
Semper Fi
Old 08-08-2020, 10:51 AM
Cardo's Avatar
Cardo Cardo is offline
Your last picture is the correct factory seal. I just had mine apart and replaced last year. That is what was in mine.
"I know just enough to keep me here, but not enough to get me out"
Old 08-08-2020, 11:11 AM
Is your's a '64 with A/C or...?
John
John 14:6
Semper Fi
Old 08-08-2020, 11:13 AM
bill ryder's Avatar
bill ryder bill ryder is offline
This topic was discussed a bit at the 2013 Dayton Co Vention, inside versus outside gasket. Seems to depend on the build date,,, maybe? What date is on the factory drawing? Outside was earlier and inside came later, maybe.,,,,, Fun isn't it???
"Bill"!
Old 08-08-2020, 11:25 AM
My 3/69 MPC doesn't show Seal for A/C applications.
Why would there be a difference between non-A/C and A/C Heater Hose Tube Seals?
John
John 14:6
Semper Fi
Cardo's Avatar
Mine is a late '65 with A/C.
Old 08-08-2020, 04:26 PM
aceaceca's Avatar
aceaceca aceaceca is offline
Same seal on 65 factory A/C car.
Old 08-08-2020, 10:10 PM
John V. John V. is offline
John, can't say about A/C builds. Or why the A/C cars were "different" when it came to the heater hoses.
You might want to review these older threads:
http://forums.maxperformanceinc.com/...d.php?t=748069
http://forums.maxperformanceinc.com/...d.php?t=654166
Note, in '64 the 9770746 seal was called "1st design". The foam seal was called "2nd design" but in the thread, some '64s apparently got both seals.
My early '64 non-A/C car was also missing the seal but I obtained an original 9770746 molded rubber seal years ago and went with it.
I see it is reproduced but not sure the repros have the p/n molded on it.
The A/C heater box is all different right? Maybe it doesn't need a separate seal? Or perhaps the A/C seal wasn't serviced? Have you looked in the A/C parts section of the MPC for a heater core seal.
Only wish mine was an A/C car. I've gotten old. In '73 or '74, my dad borrowed my non-A/C '64 GTO to commute to his office one summer day when his A/C car was in the shop. He came home soaked in sweat. I just laughed at him. Now I've become "that guy"!
Old 08-10-2020, 06:16 PM
Thanks for the replies.
I think I'll use the original foam seal from a '65 A/C car I parted out years ago.
John
John 14:6
Semper Fi
