Old 09-18-2019, 08:48 AM
DM3 DM3 is offline
Default Need your opinion regarding the quarter louvers
Need your opinion regarding the quarter louvers. I have had basically 95% if the metal replaced over the last three years. The car is looking good and almost done at the body shop. Since all the sheet metal is new, I really do not want to start drilling holes in the car. I have to drill holes in the new trunk for the aftermarket, carbon fiber rear spoiler, so there is 8 new holes already. I am not installing any of the badges so no extra holes there.
I have found original quarter louvers, but do I really want to drill 24 more holes in new quarters.... I do not plan on driving in bad weather, but I know it will happen.
My thought was grinding off the rear posts, getting an industrial strength adhesive and install them that way.
Is this a bad idea...
IG: #67MoparBird (Follow my rebuild)
1967 Firebird 400
Appeared on Gearz, Season 16, Episode 1, Segment 'What Are You Working On?'
Old 09-18-2019, 09:07 AM
Jason Rogers Jason Rogers is offline
Its what makes it a firebird but if you are going for a shaved look go all the way. It might look wierd with nothing there though. I think tape would work. Works for new cars.
I put silicone caulk all over the studs and sealed the inside before putting the nut on. It takes a really soft touch to get them tight but not strip them.
Sent from my LM-V405 using Tapatalk
Old 09-18-2019, 09:52 AM
The body shop that did my car neglected to put the quarter louvers on before they mounted the fenders after paint. As a result I double-sided taped them in place. They've been like that without issue since 2013.
The holes however were in my fenders as they were produced. So I didn't have that issue there. If memory serves me there are 4 holes per louver.
-Jason
1969 Pontiac Firebird
Old 09-18-2019, 10:14 AM
2 holes per. He's probably going to cut the posts off though.
Old 09-18-2019, 10:30 AM
68tpls400 68tpls400 is offline
I did the drill and silicone install as well. Did three '68's that way. Was indeed nervous about drilling the two holes per louver, but used a small bit first, worked my way to larger for straightness and fit. By the third car it was a piece of cake.
Old 09-18-2019, 10:59 AM
DM3 DM3 is offline
Thanks guys.
I guess my real worry is water infiltration then rust starting.
If I seal the outside and inside, maybe that will be enough. Like I said, I do not intend on driving if I know bad weather is possible. It will definitely be garaged in the winter after the first snow fall and road salting.
1967 Firebird 400
Old 09-18-2019, 11:29 AM
If that's your worry, you could cure that by adding a seam seal product around the posts prior to install. That would seal it up.
-Jason
Old 09-18-2019, 11:38 AM
Not putting the quarter trim on just makes it look more like a Camaro.
Old 09-18-2019, 12:39 PM
rohrt rohrt is offline
So they don't put the holes in the 1/4s on the replacement 1/4s?
Old 09-18-2019, 12:51 PM
I have replacement 1/4's and the holes were pre-drilled.
-Jason
Old 09-18-2019, 01:53 PM
Skins, or full quarters? I believe the full quarters do not come pre-drilled.
Or at least the five or six pairs I bought over the years didn't.
Skins do com pre-drilled from what I recall.
Old 09-18-2019, 07:29 PM
Hikin Mike's Avatar
My studs on my louvers were broken, so I used double-stick foam tape. Did that 25 years ago. Still there.
- Mike
Old 09-19-2019, 08:26 AM
DM3 DM3 is offline
It is hard to see, but the full AMD quarters, fenders and 400 hood did not come with the holes pre-drilled . I don't mind the fenders and hood since I am not installing the badges, but the quarter louvers I need the holes drilled.
I like the seam sealer idea.
1967 Firebird 400
Old 09-30-2019, 08:30 AM
DM3 DM3 is offline
So the louvers are installed, decided to drill the holes.
Put a pic of the spoiler as well.
32 holes in new sheet metal.....
ID:	521213   Click image for larger version
ID:	521214   Click image for larger version
1967 Firebird 400
Old 09-30-2019, 12:16 PM
mysticmissle's Avatar
when you said carbon fiber spoiler i did not think i was going to like it, but i do. where did you get it?
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 09-30-2019, 01:18 PM
DM3 DM3 is offline
It is a Kindig It flat out spoiler. I wanted a spoiler, but not a Camaro spoiler, so this was a good choice. I had to sell my left testicle through..... It will be painted black when the car goes to the paint shop.
1967 Firebird 400
