Old 09-01-2019, 11:05 PM
John Milner's Avatar
Default Standard wheel with 4 piston disc brakes
What would have been the standard wheel and hubcap for a 68 gto that came with 4 piston disc brakes? I have my Phs documentation and none of the wheel or hub cap options were highlighted. It had g77-14 redlines on it.
Old 09-03-2019, 10:38 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
Not an expert and surprised w/# of views no one chimed in, but they will now if I'm wrong. First off if you have nothing in box 45 or 46 your car most likely was built w/poverty/dog dish caps. The fact that it is a 4 piston disk brake car is what will make it difficult to find 14 x 6 steel wheels that won't hit , unless you have the originals ??? If not easier to go with a 15" steely until you can find correct wheel. The drum brake wheel will hit. Is that what your looking to do , back as original ?
Leo
Old 09-03-2019, 11:11 PM
6869GTO's Avatar
Should have also mentioned that if date code isn't important 69 and later 14 x 6 should fit over the calipers.
Leo
Old 09-03-2019, 11:30 PM
Thanks for the reply. I wasn’t sure if it would have came with poverty caps or some kind of wheel cover hub cap. My car’s billing history is very hard to read but I think block 45 and 46 are blank. I would like to restore the car as original as I can. Unfortunately the car’s original wheels are long gone. I will have to source some 14x6’s or maybe run some 15’s.
ID:	519412   Click image for larger version
Old 09-05-2019, 09:12 PM
6869GTO's Avatar
Nicely optioned car. Surprising to see manual disc with all the options, but w/the 4 spd not needed in my mind. My 68 is manual disc as well. Believe gold car is one that would have had body color wheel.
Leo
Old 09-05-2019, 09:48 PM
Thanks for your help. That clears a lot up. Sounds like I needs some 14x6 steel wheels for disc brakes and paint them body color. I thought it was optioned strangely too. I’m not sure I’ve ever seen manual discs before. Sounds like there is at least one more optioned that way, though.
Old 09-05-2019, 09:55 PM
Scott Thelander's Avatar
Hello .....
my 68 4 speed convert is manual disc also 4 piston ....
the HG wheel of 68 .... hey pinion head !!! help us out !! may not fit the 4 piston .... I know the rally II is a JA with no dates for 68's
and 69 w dates .... and the HF wheels of the 69 definately fit over 2 piston discs ....
some help maybe ....
Old 09-06-2019, 09:05 AM
There was a user here, user name 'TOYSWEDO', that had a lot of original steel wheels for sale at one time. You might try him.
Old 09-06-2019, 11:04 AM
Originally Posted by Scott Thelander View Post
Hello .....
Big letter JA & JC rally II's went to small letter dated versions in mid May of '68. There were some late '68's built with dated versions of both.
'67 and 68 Pontiac A-bodys with factory 4 piston disc brakes used the same caliper brackets & 4 piston calipers. A good friend, who rarely posts on this board, has a '67 GTO with factory 4 piston discs. on the '67's, DB was the disc brake 14x6 steel wheel. Drum wheels for '67 still had a big 6 up by the valve stem.
'68 Pontiac A-bodys, the codes for the std 14x6 steel wheels are different. HF's & HG's come to mind. on '68 Chevelle SS's, they received 4 piston disc calipers, though I believe those calipers are a slight different casting. XE's were '68 usage on Chevelles with 4 piston disc. XE's continued to be used up through '70 model. With the numerous different factory 4 piston calipers produced, have to double ck them all.
John, once it cools down a little, will be moving more factory steel & rally wheels over, have a huge stock to put in pallet racks, i will keep my eyes peeled. If I had an original pair of '67-68 caliper brackets handy id be in the position to jig up a stock 4 piston disc spindle with a 2 piece rotor & test fit a wide variety of 14 & 15" wheels.
Old 09-18-2019, 10:33 PM
HB 's on my buddys 68 442 w-30 w 4 piston manual disc
Old 09-19-2019, 01:20 AM
dataway's Avatar
dataway dataway is offline
OPH,
When you sort those wheels, put a April-July HG 14x6 steelie on the list, MI factory code if possible. I got the four corners covered now .... but could use a spare.
Old 09-22-2019, 07:20 AM
68ragtop's Avatar
68ragtop 68ragtop is offline
I have a full set of JC's that came from an April 68 Pontiac MI car. I think they are large font? I'll have to look into weather they are large or small stampings. I know they will fit over 69 style single calipers, but I am guessing that's a smaller setup. About 2 weeks ago & was measuring the space difference between those wheels & the 7" KS wheels I have on my car now. Seemed minimal, but maybe the 4 piston calipers are very tight fitting?
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 09-23-2019, 09:53 PM
Red Box Rebel Red Box Rebel is offline
I have front discs on my '68 GTO. It has 14" factory Rally II Wheels Stamped JA.
The Wheels fit over the factory calipers just fine.
