Old 08-20-2020, 12:23 PM
LenCaverly LenCaverly is offline
Default oil pressure drop at high rpm
I don't know how many have experienced this but i bet its not uncommon . Think about this, At high rpm there is quite a lot of blowby and in most cases it has to escape through the breathers in the valve covers, so you have blowby fighting all the oil that is trying to return to the pan. If you vent the crank case below the heads then that allows the oil an easier path back to the pan. I've seen a 15 lb increase above 6000 rpm by venting the block at the fuel pump opening. The next best place would be the valley pan but that may restrict oil also if the valley is reinforced and the middle is filled.
Len C
Old 08-20-2020, 12:35 PM
Lee's Avatar
Lee Lee is offline
I saw a dyno curve that was a bit unsteady at upper RPM, that became steady when a 1/2-quart of oil was added.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
Old 08-20-2020, 04:16 PM
Dragncar Dragncar is offline
As long as the pickup never sucks air how could blowby theoretically effecting oil drainback have any effect on oil pressure at all.
Has anyone made a fitting for taking vacuum at the mechanical fuel pump location ?
Old 08-20-2020, 04:57 PM
Herb Hagan's Avatar
Herb Hagan Herb Hagan is offline
Too much oil suspended inside the timing cover to pull vacuum from this location and it will overflow a catch can on a single pass... don't ask how I know
74 Ventura 462/#13 heads/3350#
10.38 @ 128.89 MPH, N/A, Stock suspension, 275/60 Radial, Street legal, Tagged & Insured
The Following User Says Thank You to Herb Hagan For This Useful Post:
Old 08-20-2020, 05:35 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
A 409 motor I bought in the 70s had been run in a roadster chassis and the guy had one of those big aluminum 90 degree baffled vent housings mounted on the side of the oil pan. Had a leaky sleeve so I got screwed on the motor but it did have a rare factory aluminum Z-11 water pump on it.
Skip Fix
Old 08-20-2020, 06:23 PM
Gary H's Avatar
Gary H Gary H is offline
I take my vacuum reading from a fitting attached to the fuel pump block-off plate. Mine is recorded though my data logger and it has no issues doing it that way. Steady readings throughout the runs
Old 08-20-2020, 07:49 PM
I didn't say to pull vacuum there just vent it there. I've run a piece of bent heater hose off a block off plate at the fuel pump on the dyno and seen no oil. It is not going to help a motor that has excessive blow by. I believe the reason it helps oil pressure is because less oil gets trapped in the valve covers.
Len C
Old 08-20-2020, 09:28 PM
The Steffs pan I had made has a 1/8 " pipe bung with a baffle for taking vacuum readings.
Old 08-20-2020, 11:24 PM
rod cole rod cole is offline
If you want to see this in action just take a stock Pontiac and run wide open 2 miles and watch the oil pressure drop to zero as all the oil is in the top of the motor. Happened on more than one car/engine for me.
Old 08-20-2020, 11:45 PM
slowbird's Avatar
slowbird slowbird is offline
Stock heads or aftermarket?
Old 08-21-2020, 02:06 AM
I did a ring and bearing job on a friends 352 Ford FE. Ran great, it was in a Camper Special with low gear and a granny low 4 speed. He want out drinking and decided to race some car on a long 2 mile straight stretch. Blew a hole through the block. 5 qt engines and I told him he drained the pan.
Built him a nice 390 after that, very nice engine. I said to him, don't do that of the same thing will happen.
Old 08-21-2020, 06:11 AM
steve25 steve25 is offline
Some people say these are not worth it, not me!
ID:	547673   Click image for larger version
ID:	547674   Click image for larger version
Old 08-21-2020, 10:45 AM
This is more related to aftermarket heads as some of them don't have the open real estate around the pushrods ( edelbrock) and are more prone to holding oil up top.
Len C
Old 08-21-2020, 04:03 PM
Got it covered.
Old 08-21-2020, 05:11 PM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
That’s true on mine. First race after oil change if I see oil pressure start to wiggle and drop on my Racepak I can add usually 1/2 quart and it’s fine from then on. Without the Racepak, I would never know this.
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
Old 08-22-2020, 01:09 PM
ta man ta man is offline
2 gauges I always look at when crossing strip..fuel pressure and oil pressure.
Old 08-23-2020, 06:06 AM
charlie66's Avatar
You can also put a exhaust evacution system on it. I have mine in the valve cover . At 35 pounds of boost i have a solid 90 psi of oil pressure.
My Half AN Injun.....
Old 08-23-2020, 08:11 AM
Half-Inch Stud's Avatar
Reminds me to add that Oil Pressure light that uses a Reverse Lightbulb. Stock Oil Pressure idiot Switch with cube relay is good enough...right?
Old 09-09-2020, 06:31 AM
Todd1035's Avatar
Todd1035 Todd1035 is offline
Send a message via AIM to Todd1035
Too much oil going to the top of the engine. An inherent problem with Pontiac oiling. The short fix is to keep putting oil in it till it stops. A stock Pontiac oiling system with a 60 pound pump and .030 restrictors will flow 12 GPM at the filter housing. A lot of that oil gets caught up top and takes time to drain. Ask my why I know. Lol
Old 09-10-2020, 03:16 PM
421mike 421mike is offline
Send a message via Yahoo to 421mike
Default pressure
I guess that's why Pontiac put those 8 or 10 quart pans on the early super duty 421's. I know mine never sucked dry even with the 80 lb pump.
