Old 09-07-2020, 10:10 AM
Half-Inch Stud's Avatar
Cool Labor Day Fun with a PSI calculation
Sparky got Slicks mounted to rims and set PSI to 15.00 LB each, per a trusted Gauge, while off the ground. Slick&Rim weight 20LB, and when set on ground shows a 9"x 3" contact patch while awaiting install.
When installed to car, the Slicks show a 10" x 8" contact Patch, and Rear Scales read 700 LB each.
--> Sparky checked each laiden Slick PSI with that trusty gauge; What is the new PSI reading?
(assume room temperature was constant on all items) Go
Old 09-07-2020, 10:18 AM
grandam1979 grandam1979 is offline
Old 09-07-2020, 10:59 AM
leeklm's Avatar
leeklm leeklm is offline
15lbs
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 09-07-2020, 11:58 AM
15 psi
(agree with leeklm)
Old 09-07-2020, 07:39 PM
Somewhere north of 15.00 PSI. I just don't know the calculation, nor the answer. Thanks for playing.
Old 09-07-2020, 07:51 PM
700 Lb on (10" x 8") is 700/80 is 8.75 PSI
20 Lb on (9" x 3") is 0.7 PSI.
I think the 15.00 PSI will budge to 15.01 PSI with a 1351 LB load that also produces an assume slightly larger (10" x9") contact patch, for each tire.
Representing a load just a tad higher than our atmoshperic pressure.
Therefore Leeklm & Johnta1 were BOTH CORRECT. You two are both Winners.������
