Old 09-15-2020, 08:58 PM
Mean Green's Avatar
Mean Green Mean Green is offline
Right Stuff to the rescue, and I really mean it this time. That good for nothing sealer may have actually saved your engine. A once in a million chance. I would be buying a lottery ticket!!
The oil pan on this engine was glued on with a huge amount of Right Stuff. It was a pain in the *** to get it apart. I thought I did a very thorough job of getting it cleaned up without any of it falling in the engine, but obviously not.
I'm not a fan of it, I'll stick with Ultra Grey.
www.lancablingsolutions.com
Old 09-15-2020, 09:16 PM
Mean Green's Avatar
Originally Posted by AG View Post
What do you think happened to the pushrods?
It was my fault. I originally adjusted the valves like I always have, setting lash on the base circle. Car ran great.
Someone told me I was doing it wrong and I was leaving power on the table. That I should use the EOIC method. So I Googled it, and every video I watched and forum post I read said EOIC was the proper way to adjust a solid cam.
So I adjusted them that way. Car ran great at first, next day it didn't. Pulled the valve covers and a found a couple of loose rockers, the lash caps fell out.
Thought maybe I forgot to tighten a couple of poly locks. Re-adjusted using the EOIC method again, but this time I made sure to torque every polylock. Ran great, than it didn't, again. Same thing, a couple of loose rockers and a couple of lash caps fell out.
Went back to adjusting the valves the way I always have, with some reassurance from Paul K, and it has run great ever since.
Old 09-16-2020, 08:30 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
EOIC as I learnt tit:
exhaust when intake is half closed
Intake when exhaust starts to open
I suppose the bigger the cam is, the more precise you have to be using that method. My cam is 280/285@.050, .835/.748, never any problem with them backing off.
Clutch Guys Matter
_______________________________________
53 Studebaker, 400P/th400/9"
64 F-85
72 4-4-2 Mondello's VO Twister II
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 09-16-2020, 11:18 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
I use this method, never have any issues
Old 09-16-2020, 12:55 PM
Mean Green's Avatar
My cam is smaller than yours.
I never heard of that method until 3 weeks ago. Apparently it works in most situations, but it didn't work with my cam, so I'm going to stick with my way.
The way I see it, if the cam calls for .020 lash (or whatever), there should never be a point where there is more than .020 clearance. Which ever way you get to that point shouldn't matter.
Old 09-16-2020, 01:57 PM
GTOGEORGE's Avatar
Ditto! Works for me.
GTO George
Old 09-16-2020, 02:41 PM
Mean Green's Avatar
Originally Posted by Geoff View Post
What brand chain is it?
Rollmaster
Old 09-17-2020, 04:43 AM
Geoff Geoff is offline
Some RM sets were using Rolon timing chains. I have one in the cupboard, still in the box, free to whoever wants it. Says 'Rolon' one side, 'India' on the other side...
Old 09-17-2020, 02:19 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
That is the only way I do it and one cylinder at a time so I do not forget one. But Exhaust as intake is closing. You want to be as far away from overlap as you can. If intake is about to close it is close to compression before firing so exhaust should be on base circle. Exahust opening shoudl be way away form overalp as that happens as exhaust is closing to scavenge and pull intake charge into cylinder.
Skip Fix
