Old 08-15-2009, 11:41 AM
SWEETMUSCLE's Avatar
SWEETMUSCLE SWEETMUSCLE is offline
Default 1967 intake manifold
H date code with vacuum switch 200 $ sand blasted and hot tanked
Name:	ebat  64 heads and 67 intake 001.jpg
ID:	178128   Click image for larger version
Name:	ebat  64 heads and 67 intake 002.jpg
1969 black on black 4 speed judge
1964 silver 4 peed tri power convertible 3:90 rear
Old 08-17-2009, 08:09 AM
ericthewellread's Avatar
ericthewellread ericthewellread is offline
Smile
Isn't that part number for a 1968 intake?
Old 08-17-2009, 05:39 PM
Blackwood Goat's Avatar
Blackwood Goat Blackwood Goat is offline
Default Manifold
I believe that casting number is for a 1968.
If everything seems under control,your just not going fast enough. Mario Andretti
________________________________________
May God have mercy upon my enemies, because I Won't. General George Patton
Old 08-17-2009, 05:41 PM
Region Warrior's Avatar
Yep, 68.
Old 08-17-2009, 09:11 PM
gtoraz69 gtoraz69 is offline
Default intake casting
Hello, That casting appears to be for the 1968 but I also have an intake and take a look at this casting and date code?? I am confused. Please can someone shed some light? Thanks Tom Razz
ID:	178464   Click image for larger version
ID:	178465   Click image for larger version
ID:	178466   Click image for larger version
Old 08-17-2009, 09:18 PM
Old Goat Racer's Avatar
Friday night drunk at the foundry ?
Everybody knows somthin.
Nobody knows everything !
Old 08-17-2009, 09:25 PM
Here's a picture of a 1967 intake. The exhaust heat passage running under the front of the carb is the first big difference you see between the '67 intake and the others.
