When A Crack In The Manifold Really Matters
Hi,
How serious is having a couple of cracks where they usually appear on a 1966 tripower manifold? When do you need to replace the manifold? Thanks, Don
1966 GTO 1966 421-9.3-1 comp-Race Tec 23cc Pistons 1966 Tri-Power 1967 670 Heads Pontiac "Highlift" TriPower Cam by SpeedPro DUR 214 Int 224 Exh @.050 - 107 ICL LIFT .445" Int .465" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
It depends on where the cracks are and how much leakage you have. They usually crack at the heat riser passage. If you have that blocked, it's a non-issue. If in the water crossover, coolant leakage would not be acceptable--but they rarely crack there.
If the cracks are in the runners, vacuum leaks will affect idle, and need to be fixed. Welding or epoxy are two options. A used '66 intake is about $300-400. An aluminum repro costs about the same, but they have quality issues so you would need to do a careful inspection before using.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
The Following User Says Thank You to Dick Boneske For This Useful Post: | ||
