Old 09-17-2009, 08:53 AM
vev78 vev78 is offline
The Evans web site is not accesible again today. Do they make this pump for the older 8 bolt pattern pumps?
Old 09-17-2009, 09:34 AM
71 T/A 71 T/A is offline
I saw on their site that Evans will rebuild your water pump to their specs, which is great if you want to keep your stock, possibly matching numbers pump. Also, the hub is thicker and looks stronger than others I have seen and they include a bleeder valve to let out trapped air.
Old 09-17-2009, 10:41 AM
My stock pump is long gone. I am just looking to get as much help with cooling as possible. It sounds like they make a nice pump based on all the info on this forum. It is worth a try for the price. Not really sure if anyone posted an answer on the evans coolant. Does this stuff cool better than water antifreeze combo?
Old 09-17-2009, 11:56 AM
Karch Karch is offline
Supposedly their coolant is superior to water based anti-freeze, but it's not compatible with water, so you have to remove all the water/anti-freeze from your entire system (engine included).
Also, I remember hearing something about it being flammable, but I am not sure.
I was thinking that it may be great for air-water intercoolers
How many of you have driven over 340?
Old 09-17-2009, 12:02 PM
You have to use their coolant when adding or you can use Sierra coolant - but that's it.
