#41
I am hoping to, but on the last car I restored where I said "it'll be done next summer" I said that 2 or 3 times before I picked the right summer.
-Jeremy 1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio. 1962 Catalina convertible, Starlight black w maroon interior & white top. |
#42
Jeremy,
Good job on the frame. I just put my Chassis together this past summer and got the body back on it. Keep up the good work. Regards, Anthony |
#43
Rotisserie is done, car is no longer up on blocks or posts. I am kinda nervous about removing the blocks, is this normal? Is it a good idea to let it sit for awhile on a new rotisserie before removing the blocks? Or is it OK to use as soon as all the weight is on. This is my 1st time doing this.
#44
Scraping is going well. I am using easy off heavy duty oven cleanerand following that up with simple green and a red scuff pad.
#45
Hey Webfoot,that rotisserie looks awesome! What it cost you to build and where did you get the plans? Your doing an awesome job dude,keep the pics coming.
#46
I am borrowing the parts from a friend, it was only half assembled when I got it. No plans that I know of, but if you are interested I could give you a build list.
One of the upsides to having to patch the floor is you take the old undercoating crap off with the bad section! I have since been told that playing with undercoating is potentially hazardous and I have been wearing a respirator since. Anybody want some cinder blocks? You just pay shipping!
#47
Thanks ,build list would be cool to have. Don't think the undercoating is as bad as the sh*t from blasting,but I see in your posts you've been wearing a mask for that as well,,good!! My oldest son is out your way,,kind of,,will be graduating from college in Salem OR this coming spring. Nice part of the country,Oregon.
#48
I'll get you that build list at some point. I actually lived in Eugene for 5 years and then Salem for 3 years or so before I moved back to the non-rainy side.
Almost done scrapin' stuff, even got a wheelwell done last night. If there is a zone to be in for scraping, I was in it! (The orange spot in the 1st pic is from the flashlight I was also holding - poor garage lighting) Now to grind welds on this side, and finish welding up a few hard to reach spots, mainly in the trunk. Floors are rock solid by the rockers, what you see is surface rust. Can you tell the pass side rear floor patch was my first patch job ever? Gonna take a bit of grinding over there. Should that "pimple" be there on the wheelhouse? I didn't think so, but I also can't see a dent from the trunk side - maybe need to take another look. If not I'll hammer it back out.
#49
No hurry for build list,for future project.Yes dimple/pimples should be there.Once you grind the weld,blast and prime that floors going to look awesome.
#50
That is my exact plan, going to use either DP90 or SPI epoxy. Then use that cool spatter paint in the trunk.
#51
Meant to add that you can see the dimpled area just above and behind hinge support in posted pics of my 68.
#52
Looking great! keep it up!!
"If you can’t fly then run, if you can’t run then walk, if you can’t walk then crawl, but whatever you do you have to keep moving forward." |
#53
Warmed clear up to over 50 so I painted the air cleaner. Had lots of pitting to clean up and a few dings too and I am quite pleased with how it turned out. Do they make a rubber seal that goes into the bottom of this, if so where can I find it?
#54
Air cleaner looks great. Guess you don't like the 68 air cleaner?
#55
Car didn't come with one, and I think the dual looks much better. I got a good deal on this one from a member here so it just made sense. Car doesn't have any numbers matching stuff so I felt it was OK to change it a bit with factory stuff. Converting to power discs & steering and will use ram air exhaust manifolds too.
This is how it looked when I got it:
#56
Your right about the dual looking better. Keep the pics coming,,your definitely committed to keep moving ,,,great progress.
#57
Didn't get much done in december - kinda cold. It has been kinda "tropical" for over here this winter with temps in the 50s. Also I got a bunch of new garage lighting and it is much nicer working.
Now its time to focus on the motor. Once I figure out which throwout bearing I need the engine and trans are going in. Heads should get rebuilt in the next month or so.
#58
Looking good. Your getting there. Best part is assembly, everything is nice and clean.
Send it! It’s going home on a trailer. |
#59
Been busy - got steering box and all steering linkage installed, motor dropped, clutch installed - can't seem to get a ball stud around here so I ordered one, it will be here next thursday. (aargh) Bearing should have been today, where are you Fedex guy?
#60
Jeremy,
Thanks for posting all these great pics. Nice work! Inspiring too. Your crank and w/p pulleys caught my attention because the w/p pulley looks bigger than the crank pulley which underdrives the water pump. It may be nothing, it may be perfect resto, but so many of us have overheating issues that I just thought I'd say something.
- Tom |
