Old 01-09-2018, 01:15 PM
rambow rambow is offline
Default Bucket/Bench/Rear seat Padding Install & Repair kits
Getting ready to restore your car's seats, but don't know what all you might need once you get the old covers off?
I sell kits that include all the OTHER stuff you will need.
Bucket Seat Padding & install Kit - 64-72
Kit contains material to re-build (2) bucket seats:
(4) 25x25 burlap squares
(4) Precut jute decking sets (1 center, 2 bolster pieces per cushion)
(2) Jute spring insulation sets (lower fronts, lower inner & outer sides, upper cushion top center)
(4) 60" paper covered wire rods (for use inside the lower cover sleeves, or to replace the listing rods on the spring assemblies)
(5ft) 11ga Medium loop springs (bottom & upper cushion)
(5ft) 9ga medium loop springs (bottom cushion)
(35) spring clips
(1) bag of hogrings (enough for pair of buckets)
Bench Seat / Rear Seat Padding & Install Kit
Kit contains material to re-build (1) front Bench seat, or (1) Rear Seat:
(2) 66" burlap sheets
(2) 66" Jute decking sheets
(4) 60" paper covered wire rods (for use inside the cover sleeves)
(35) spring clips
(1) bag of hogrings (enough for 1 bench or 1 rear seat)
These kits are $80 each+$19 shipping (USPS Flat Rate large)
Buy two kits and I will take $20 off the total.
Have specific seat spring repair needs?
Tell me when you order and I can make them here and include them ready to install with your kits materials.
ben@classicseat.com
ID:	472052   Click image for larger version
ID:	472053   Click image for larger version
ID:	472054   Click image for larger version
ID:	472056   Click image for larger version
Old 10-02-2018, 06:47 PM
ttt...
Its fall, a great time of year to start thinking about restoring your seats!
Old 05-22-2020, 12:09 PM
ttt
I'm still making the seat install kits!
Prices have gone up a little since this was posted.
Kits are now $100 each + $20 shipping to USA (USPS Flat Rate)
Discount still applies, buy 2 kits (front and back) and i'll knock $20 off the 2nd Kit
Old 05-22-2020, 02:13 PM
alsalp alsalp is offline
" paper covered wire rods " Does that replace the thin wire grid bonded to burlap from factory?
Old 05-22-2020, 06:47 PM
No, these paper covered rods are 16ga, and they replace the paper covered rods that went inside the sleeves for installing the seats, and were attached to the spring assembly for the bolster listings to attach to.
I believe Al Knoch reproduces those burlap woven with music wire rods for a stagering $120 or so.
