Old 12-28-2019, 08:50 PM
gloryrestoparts's Avatar
gloryrestoparts gloryrestoparts is offline
Default first gen axle shafts
looking for a pair of first gen axle shafts for my 68 8.2 BP housing. Would prefer nodular, but any good shafts will do. The closer to Chicago the better as I don't really want to deal with shipping.
Thanks,
Chris
http://gloryrestoparts.20megsfree.com/
1970.5 Pontiac Tempest GT-37
400ci 4bbl 4sp 3.90:1
12.73 @ 112.42 2011 Pure Stock Drags
12.71 @ 110.58 2013 Martin FAST/FS race
12.70 @ 111.74 2014 Pure Stock Drags
12.60 @ 111.66 2015 Martin FAST/FS race
1968 Pontiac Firebird 400
TH400/3.08 open
export car - factory heater delete
14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags
14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race
Old 12-28-2019, 09:42 PM
tri.lllgto tri.lllgto is offline
Default axle
Same axle as 65 1/2-69 Pont 'A' If you can't find any down there. I have plenty in Milwaukee.
Old 12-29-2019, 02:48 PM
Thanks. I wasn't sure if they were the same or not.
TH400/3.08 open
Old 12-29-2019, 04:42 PM
Having ran across more than one very original early '66 with a dated late '65 production rear in it, the earlier 8.2 Pontiac & 8.2 BUICK rears both had the shortest axles.
For an original '67 or '68 Firebird rear that would make the choice of stock axles that properly interchange to be
- '66-69 Pontiac 8.2 axle (w exception of very very early '66 builds)
- '66 or '67 BUICK 8.2 axle with RW507CR bearing (not Buick Buick Sportwagon or others with larger RW508 axle bearing)
- also... '67-69 TYPE "O" Olds 10 bolt 28 spline axle. Sealed axle bearing, 3 holes in the axle flange, 28 splines.
IF the rear is a stock Pontiac 8.2 HD Safe-T-Track & the axles are chewed under the sealed bearings, your best choice is to buy a new pair of Moser or Dutchman axles, nice used originals are near extinct. In 35 years of tearing down sealed axle bearing 8.2 HD STT rears, there has been only one instance where the Nodular housing was junk & the whole mess yielded a nice pair (after cking bearing lands) of forged axles.
Old 12-29-2019, 09:46 PM
is that right. Well, I have several 69 Type O axle assemblies sitting around. Guess I get to check them out and see if the shafts are good.
Thanks for the info on the nodular stuff. I suspected they might not be the easiest to find and I was leaning towards Moser anyway. Pretty sure that's the route I'll take when I build the 68 nodular housing with the Eaton carrier and 4.33s. That's a couple years away for what it's worth.
oph, BIG thank you for the info.
TH400/3.08 open
