Old 11-29-2020, 01:30 PM
68hotbird 68hotbird is offline
Default WTB 69-72 power top switch
looking for a power top switch in good working condition. Thanks Paul.
Old 11-29-2020, 08:24 PM
tri.lllgto tri.lllgto is offline
As far as I know, 69&70 is one.(which is reproduced & in catalogues). 71/75 when they changed body styles is something all together different & not reproduced. What do you need.
Old 11-29-2020, 08:29 PM
Default switch
69-70 also fits 69-72 a body cars. I have a reproduction and the quality is poor.
Old 11-30-2020, 08:02 PM
You missed the point. Your ad isn't under A-bodies. It's under B-body. They aren't the same.
Old 11-30-2020, 08:15 PM
rockys1970 rockys1970 is offline
I beleive the switch is the same but the length of the wiring harness is much shorter for a B-Body. The A-Body switch is located to the right of the steering column and the harness is routed over the instrument cluster. The B-body switch is located to the left of the column therefore the harness is much shorter. I remember pulling one from a 1969 Catalina in a junk yard years ago.
Old 11-30-2020, 10:16 PM
The Pontiac parts book shows the same part number for all 69-70 convertibles b body f body and a body. This is a 1970 parts book so I can't go newer but from other replies b body changed in 71.
Old 12-14-2020, 08:04 PM
Default switch found
Found a nice switch thanks to PY thanks for everyone that helped. Paul.
