Old 07-28-2019, 07:22 PM
tri.lllgto tri.lllgto is offline
Default 4OO, 421, 455 blocks & Nodular Rear ends & GTO heads delivered to Norwalk
We have the following 4-bolt blocks going to Norwalk-421, 400, 455 prices from $1000-$2000, 3.55 Nodular posi rear ends-$1000, #77 & 093 heads-$450, 7F6-$2000, 73 SD #16 (fresh)-$4500. Just look for the big ambulance.
Old 07-28-2019, 08:06 PM
tom s tom s is online now
4 bolt cap blocks or drilled for four but 2 bolt caps.I know all 421s are 4 bolt caps.Tom
Old 07-29-2019, 09:04 AM
ANDYA ANDYA is offline
What is the year and code of the 421 block and is it standard bore?
Old 07-29-2019, 07:14 PM
Default blocks
The 421 is a 65 YH at 30, will clean up at 40. I advertised 4 bolt blocks. Not 4 bolt blocks with 2 bolt caps.
Old 07-29-2019, 08:15 PM
Just checking as many 4 bolt drilled have been advertised as 4 bolt blocks.Tom
Old 01-29-2020, 12:05 AM
GTO66 GTO66 is offline
What are the date codes on the 093 heads?
Thank you.
