#61
Are they all on seperate relays?
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. |
#62
I checked out the Spal website, their 16" fan is rated 2800 CFM and 22 Amps.
Their 9" fan is 740 CFM and about 10 amps. That's running current, keep in mind that the starting current for these fans can be 3-5 times the running current. George
#63
George,
Would I be better going with 2 smaller fans, than using the one big fan? Would it pull less current to run 2 smaller fans? Would I get the same cooling power with 2 smaller fans than one big fan? Biltit, I am not sure what you guys mean by relays? Each one is on its own toggle switch on/off that is it. I kind of know what a relay is, what advantage would it do for me rather than just having them on on/off switches? Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, TCI Flex plate, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi. |
#64
65: at least with 2 smaller fans, you can "stage them" i.e turn on one at a time, relaxing the initial electrical load. You can also turn on only one if it'll do the job of cooling.
Mechanically 2 fans may cover more of the total area of the radiator rather than one large one. A relay is a electrical device where a small current in the relay coil controls a large current to a device like a fan. Typically you can run a shorter heavy wire from the battery to the relay and then to the device (fan), and a smaller wire from the relay coil to a toggle switch. The toggle switch only needs to carry the small relay coil current. Using the fan as an example, the main advantage is you don't need to run a large gauge wire from the battery to the toggle inside the cabin and then back out to the fan, You can have the relay under the hood, kind of how a horn relay is typically used. George
#65
http://forums.maxperformanceinc.com/...d.php?t=454036
Some good reading on relays. You DO need relays if they are not already installed!!!!
#66
The alternative that you might be experiencing is having 12 degrees total advance at say 1,600 RPM and the RPM drops off a little and the engine drops back to its baseline 6 degrees initial advance - engine drops off a cliff and RPM drastically drops.
#67
Also, I don't believe this was mentioned above, sorry if it has been. Rather than run a large fuse I simply came off the main power feed with a short 6" section of 14 gauge fusible link attached to the 8-gauge to the relay and 8-gauge to the fan motor. I'm running the Mark-VIII fan and while it does draw big current the system has worked excellent. The fusible link will take the high initial amp loads with ease, but still protect the fan circuit. I also run two relays in parallel for each fan speed. The electric fan is on the drag car where I don't turn it on until after the finish line. I still much prefer the stock fan with HD fan clutch for my street rides.
