When putting my evaporator back in my ac box, what do i use to replace the black wrap that seals around the pipe coming out of the front of the box(the stuff that looks like its hand pressed around it originally).
thanks!
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi. Everything installed, fired up and tuning has begun! |
thanks!
there's a product sold by four seasons that is used for this. it's also used to insulate the poa valve's temp sensor from the ambient air in the engine compartment. it's sold thru carquest and napa stores and runs about $20.00 a box. the box will be way too much for what you need.
if you want a part # e-mail me the first of the week and i'll get it for you. mike
thanks alot, i will check those stores out and see if i can get them to understand me [img]smile.gif[/img] . If not I will email you for the part number.
thanks again
