Personal best
I've been trying to get my 69 firebird into the 11's for a few years now. First pass off the trailer yesterday the car does an 11.76 at 119 mph!!! I usually launch the car at about 3000 rpm, this time I came outta the hole at 1800 or so. The car actually hooked and booked down the track. It was a really good run and I figured it at least had to be as good as my previous best of a 12.04. When I got the time slip I could not believe it.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
The Following User Says Thank You to 4dblnkldude For This Useful Post: | ||
Congratulations! That is a great feeling when that time slip is a new best. What is your combo?
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
It is a 455 .030 over, e heads slightly ported, xe-284 cam, 1.65 HS rockers, edelbrock torker with water crossover separated, 850 4150, dougs headers, TKO-600, ford 9" with 3.89:1 gears, cal tracs, cal trac split monos. The 10 bolt nodular rear got eaten by this combo. I know it can get faster with an auto. I could also put some wider tires on it but this is a street car, will never be tubbed, or have a cage in it.
Nice!! 119 shows enough hp to go a couple more tenths quicker but would have to be a hard launch considering the manual trans.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
That is a really good mph for a 11.70 your making some good hp. Congrats on the new best.
What tires are you running?
M&H racemaster dot street slicks. 245/45/17. I dont know if a 275 will fit in there. Funny thing is I know what I have to do to get it to hook better at higher rpm I just don't want to do it. I ordered a roller cam kit from butler last year to swap in to see if that would get me into the 11's..so now what do I do. I was gonna pull the engine the day after thanksgiving to swap it in among other things, I guess I still will, not like I can return it after over a year.
Man, that is a really good pass with a 5-speed. If you had an automatic and more cam I bet you would see low 11s at least. What was your 60' time?
Curtis runs the MT ET street drag radials, 275/60x15 and they fit nicely in the 69 wheel wells but the backspacing needs to be just right. Can't remember that measurement off the top of my head but I could look it up. What size roller cam did you get from Butler?
I only went a little bigger at 242/248/112 duration. The lift with 1.65's will be .619 and I think .591 on the intake. I think I'm going to advance the cam 2 degrees. I'm hoping the roller cam will smooth things out a little. I think my back spacing is 5 3/4". I had 18x10 on the back at one time.
Oh 60' was 1.72.
Awesome run congrats! What changes did you make to knock off 3/10s? Really impressive with a manual trans
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
I did drop the exhaust and take the air cleaner off. All of my other 12.0 runs were still at 117 or so.
Congrats Matt - that's the way to "get into" the 11's alright. If only going fast didn't always lead to going faster this would be a lot easier haha. Not sure what I would do now but whatever you decide: good luck.
Happy Thanksgiving
Ain't as good as I once was, but I'm as good once as I ever was. |
My cousin's T/A was way rich, and gained big e.t./mph when he opened his exhaust. One of my cars was jetted dead-on, and had horrible lean-stumble when I opened the exhaust on it. Something for you to maybe consider & test. I ran 275/60-15 MT drag radials on my '67 Firebird. It would 60' as low as 1.53, running 24psi. I drove the same tires on the street, and never had an issue, never rubbed. That same car ran 11.2's when I got the MPH to 119, so get ready to be told to get a rollbar! :-)
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust My webpage http://lnlpd.com/home |
What is your exhaust? 2.5-3” over rearend?
